• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Play movie clip buttons that will only go forward/back in consecutive order
Participant ,
Jun 22, 2018 Jun 22, 2018
Hello -
I need to work out how to have buttons that will only work in a certain order. So button1 must be clicked first (play movie clip1), then button2, then button3. You can't click/play button3 before clicking/playing button1, and button2 first. And when going in reverse they can only go back one step so if on button3 they can only click button2 or continue forward by clicking button4. I've looked through forums and googled, can't find anything on how to set this up. I'd appreciate any help.
Here's what I'm currently using for buttons to play the movie clips (Count1, Count2, etc). All of this functions like I need it too except having them only play in order. I'll also need to add a reset button once I figure out how to work in order.
var playing:Boolean = false;
function stopAllCounts():void {
     Count1.gotoAndStop(1);
     Count2.gotoAndStop(1);
     Count3.gotoAndStop(1);
     Count4.gotoAndStop(1);
/*1st movieclip*/
Count1.stop();
function startCount1(event:MouseEvent):void {
     var stopped:Boolean = Count1.currentFrame == 1 || Count1.currentFrame == Count1.totalFrames;
     stopAllCounts();
     if (stopped) {
  addChild(Count1);
          Count1.gotoAndPlay(1);
startButton1.addEventListener(MouseEvent.CLICK, startCount1);
/*2nd movieclip*/
Count2.stop();
function startCount2(event:MouseEvent):void {
     var stopped:Boolean = Count2.currentFrame == 1 || Count2.currentFrame == Count2.totalFrames;
     stopAllCounts();
     if (stopped) {
  addChild(Count2);
          Count2.gotoAndPlay(1);
startButton2.addEventListener(MouseEvent.CLICK, startCount2);
stop();
/*3nd movieclip*/
etc......
Views
651
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jun 22, 2018 Jun 22, 2018
Hi.
I don't know if this is exactly what you want, but I hope this helps somehow.
AS3 code:
import flash.display.SimpleButton;
import flash.events.MouseEvent;
var buttons:Array =
{button:button0, toggled:false},
{button:button1, toggled:false},
{button:button2, toggled:false},
{button:button3, toggled:false}
function mouseHandler(e:MouseEvent):void
if (e.type == MouseEvent.CLICK)
  if (e.target.name.indexOf("button") == 0)
   var ind:int = int(e.target.name.slice(6, e.target.name.length));
   b
Votes
Translate
Translate
Community Expert ,
Hi.
AS3 code:
var buttons:Array =
   buttons[ind].toggled = !buttons[ind].toggled;
   setOrder(buttons[ind].toggled ? ind : ind - 1);
   this["bar" + ind].gotoAndPlay(1);
function setOrder(index:int):void
for (var i:int = 0, total:int = buttons.length; i < total; i++)
  if (i <= index || i == Math.min(index + 1, total - 1))
   buttons.button.alpha = 1;
   buttons.button.mouseEnabled = true;
  else
   buttons.button.alpha = 0.2;
   buttons.button.mouseEnabled = false;
   buttons.toggled = false;
   this["bar" + i].gotoAndStop(0);
addEventListener(MouseEvent.CLICK, mouseHandler);
setOrder(-1);
FLA download:
animate_cc_as3_click_sequence.zip - Google Drive
Regards,
JC
Votes
Translate
Translate
Report
Report
Participant ,
Thanks JC. Yes! Excellent. This is sooo close. Okay, it's working with all the buttons. I need to figure out how to stop the previous movie clip playing if the next btn is clicked and starts playing. I've got audio involved so it has to stop any other clips so they don't overlap sounds. Do you know what I would add and where in the code you provided?
Votes
Translate
Translate
Report
Report
Community Expert ,
Jun 23, 2018 Jun 23, 2018
Good Job  JC! I was working that code, but I couldn't get. Glad you were able to help.
Votes
Translate
Translate
Report
Report
Participant ,
Jun 26, 2018 Jun 26, 2018
LATEST
This is almost there. The buttons work well when clicked in order going forward. However, when clicking backwards things get glitchy. The buttons are either all able to be played or as you go backwards only the first button works and has to be stopped before the next button will work again. Anybody have any suggestions?
To either the original code posted or the code offered by JC and modified to include stopping the previous movie clip when moving through the buttons:
TESTING click btns in order_2.fla - Google Drive
TESTING click btns in order_2.swf - Google Drive
var buttons:Array =
               if (i < index)
          else
setOrder(-1);
Votes
Translate
Translate
Report
Report
