• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
1
Where are the timeline panel column properties stored on Windows?
Engaged ,
Jun 24, 2018 Jun 24, 2018
I'm running After Effects CC 2014.2.0 on Windows 10.
By default, some of the following items in the timeline panel are not displayed by default.  For example, see the "mode" and "key" columns I've pointed out in red in this image:
I also don't have the columns in the same order as typical (I moved over the column containing the "solo layer" button, for example, to the right of the layer name instead of the left, which is the default).
On another machine, I copied the entire %AppData%\Roaming\Adobe\After Effects\13.2 folder over to a brand new install of this particular version of After Effects.  Believe it or not, all those changes that I had made to the timeline panel columns appeared!
So this tells me that, somewhere in this folder, in one of these files, this information is stored.  However, does anybody know exactly WHICH file?  I see this entire list, but I want to know which one in particular contains this information:
If you know the answer, please share, and also please share where you found this information; I don't see any documentation on this, and I'm really interested in knowing.
Views
1.4K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged , Jun 24, 2018 Jun 24, 2018
I actually did find them, eventually; turns out they're in the "Adobe After Effects 13.2 Prefs.txt" file.  Specifically, it seems to be located in the "Pref_New_SORT_PANELS_TL v2" section of the file.
Votes
Translate
Translate
LEGEND ,
You will find them in the AE project file.  They are not kept in a separate file.  Good luck retrieving them.
Votes
Translate
Translate
Report
Report
Engaged ,
Votes
Translate
Translate
Report
Report
Explorer ,
Mar 22, 2021 Mar 22, 2021
And, please, anybody knows where is the "project panel" default columns order? I want to have label first and I need to change it in every new project..
Votes
Translate
Translate
Report
Report
New Here ,
Nov 17, 2023 Nov 17, 2023
LATEST
Votes
Translate
Translate
Report
Report
