1 Reply Latest reply on Jun 27, 2018 1:35 AM by KrispySalsa
    Adobe Launch with Drupal 8
    KrispySalsa Level 1
      Hi One and all,
      Has anyone out there used launch with Drupal8?  I have a very simple test JSON defined data layer, which looks like the below
      <script>var digitalData =
      {"page":
      {"pageInfo":{
      "pageName":"Home",
      "destinationURL":"\/home",
      "breadcrumb":"\/home",
      "pageCategory":"page"},
      "channel":
      {"primaryChannel":"home",
      "pageType":"page"},
      "attributes":
      {"language":null,
      "contentType":"page"}}}];</script>
      we would use JS, except Drupal8 doesn't like you out putting native JS to the page, so my developers advised to use JSON.  The issue I have is when I use _satellite.getVar('page Name'); I get a result of (" "), as far as I can tell all the config is correct inside the Launch UI, I have created a data Element with the name of page Name, the path to the data element is digitalData[0].page.pageinfo.pageName (Which I believe is correct).
      When I inspect the DataLayer with Data slayer, all the elements are visible and populated.  I am trying to understand why the data layer elements are empty when I use the  _satellite command.  I hope this is enough info.
      many thanks in advance.
        • 1. Re: Adobe Launch with Drupal 8
          KrispySalsa Level 1
          Hi All,
          Adobe Client care have solved this issue.  The resolution to edit/create the  data element and use the core extension, then element type should be Custom code as below
          once the editor opened I added the following code
          the above code works for thew JSON dataLayer in Drupal 8
