Expand my Community achievements bar.
Join us at Adobe Summit 2024 for the Coffee Break Q&A Live series, a unique opportunity to network with and learn from expert users, the Adobe product team, and Adobe partners in a small group, 30 minute AMA conversations.
SOLVED
Failure in SAINT import for report suite through API
Avatar
Level 2
every time when import the data in report suit through Analytics 1.4 APIs its showing the following error
Import Status
Error:First column is required to be the key
So can you please in this, where i make mistake if possible please send me some demo code with two columns like 'Key' and 'Category Field'
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
Might help if you post your present code format that is causing the error.
Also make sure first line of API request is indeed the the SAINT 'key' variable.
View solution in original post
Avatar
Correct answer by
Community Advisor
Avatar
Level 2
"check_divisions":"0",
"description":"Import Video CSHK",
"element":"evar9",
"email_address":"xxxxxxxxxxxx,
"export_results":"0",
"header":[
"( 'Key','Video Category')"
"overwrite_conflicts":"1",
"rsid_list":[
"ags545cgdev"
For PopulatedImport
"job_id":"21564875",
"page":"1",
"rows":[
"row":[
"('adsadsad','jhjhgjhgj')"
Avatar
Community Advisor
ok for clarity what are the elements you are trying to import?
Can you rank them and then also highlight which one is the Key variable?
Avatar
Level 2
header":[
These are the element, key and video category
And I import these value from populated import method and values are
Avatar
Community Advisor
ok so to verify you have an evar9 that is called "Video Category"?
Would I be right in saying you could have an evar designated to "Video name", you then want to use SAINT to create a Category group for it?
Also I see a little space in your code that could be tripping up things..
YOUR copy
header":[
DELETED extra space in front of key
header":[
"('Key','Video Category')"
Avatar
Level 2
I have tried with this  when i create import job it show me a job id, with that job id if i populated import it show me result "true" and after commitimport it also show me result "true",
But every time a got error email from adobe '
Please if possible can you provide me a sample code for all three stages with a sample element
