3 Replies Latest reply on Jun 29, 2018 3:18 PM by Ten A
    Questions about csInterface.hostEnvironment.appSkinInfo and reading the app UI
    Tom Scharstein II Level 2
      Hey guys, I thought it was strange that appSkinInfo doesn't include very much so I've started my own version for Illustrator, After Effects and Photoshop:
      It works decently well at the moment though one or two colors are slightly off (like Highlight on the Light theme). In theory this should prevent any miscolored panel elements, backgrounds or text and would auto-update for recoloring, adding basic eventListeners and logging all UI data into a global object for storage, but I'm a bit confused as to where some of the information is coming from or what it's referring to. From the CSInterface file:
       * @class AppSkinInfo
       * Stores window-skin properties, such as color and font. All color parameter values are \c #UIColor objects except that systemHighlightColor is \c #RGBColor object.
       * @param baseFontFamily        The base font family of the application.
       * @param baseFontSize          The base font size of the application.
       * @param appBarBackgroundColor     The application bar background color.
       * @param panelBackgroundColor      The background color of the extension panel.
       * @param appBarBackgroundColorSRGB     The application bar background color, as sRGB.
       * @param panelBackgroundColorSRGB      The background color of the extension panel, as sRGB.
       * @param systemHighlightColor          The highlight color of the extension panel, if provided by the host application. Otherwise, the operating-system highlight color.
       * @return AppSkinInfo object.
      This seemed pretty self-explanatory until I began expanding it to include every conceivable UI color and seeing the elements change in real time and all the values of the text in the panel updated. Illustrator and Photoshop both report Tahoma as their Base Font Family and both report 10px Font Size, but that's not correct because Illustrator looks like it has a higher DPI (or Photoshop a lower one) and this same panel in Photoshop has text that looks as much as 1.5 times as big as it should be (despite both having the same 10px font size). After Effects says the base font is Adobe Clean -- where are these Base Fonts coming from and what are they referring to? The font's inside the app are clearly san-serif (UI, input text, menus, everything that I see) and very clearly not a serif like Tahoma. So where does it get Tahoma from, and what is the actual font that Illustrator or other apps use for their UI?
      What is appBarBackgroundColor? The description makes it sound like it would be the header of panels in After Effects or the darker, top section of a window, yet in all apps I've tested it returns the same color as the panelBackground. Also, systemHighlightColor always gives me the OS highlight and never a host app color so I had to make them myself. Essentially, I found the only useful properties of AppSkinInfo were baseFontSize and panelBackgroundColor, and that all the others either seem incorrect or produce results that clearly don't match the UI. Am I wrong here?
      Your post moved from Illustrator Scripting to Extensions / Add-ons Development by Moderator.
