This content has been marked as final.
Show 5 replies
1. Re: Embed tage not found durin Validation
Newsgroup_User Mar 19, 2008 3:33 AM (in response to INVT)> The tag name: "embed" Not found in currently active
> versions.[XHTML 1.0 transitional]
<embed> is not a valid HTML tag, although it is required for some browsers.
Your code will never validate when using DW's current insert Flash feature.
However, this likely has nothing at all to do with your issue.
Is the file containing the code below at the same folder level as the Flash
files you have linked/embedded? That's where the links are pointing....
Murray --- ICQ 71997575
Adobe Community Expert
(If you *MUST* email me, don't LAUGH when you do so!)
http://www.projectseven.com/go - DW FAQs, Tutorials & Resources
http://www.dwfaq.com - DW FAQs, Tutorials & Resources
"INVT" <webforumsuser@macromedia.com> wrote in message
news:frqdfv$ioa$1@forums.macromedia.com...
> The links to my flash does not work. IF I test the file out of the folder
> it is
> in using Bridge it works fine or through windows but when I bring it into
> DW
> and preview the links do not work.
> I sued the html Flash cs3 created and the links did not work so I added
> the
> Flash object and in DW and it still did not work then I validated the code
> and
> it tells me; The tag name: "embed" Not found in currently active
> versions.[XHTML 1.0 transitional] this is the page code:
> <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
> " http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html
> xmlns=" http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
> <head>
> <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1" />
> <title>slideshow</title>
> <script type="text/javascript">AC_FL_RunContent = 0;</script>
> <script src="AC_RunActiveContent.js" type="text/javascript"></script>
> </head>
> <body bgcolor="#ffffff">
> <!--url's used in the movie-->
> <a href="iconcards.swf"></a>
> <a href="doorsitaly.swf"></a>
> <a href="light.swf"></a>
> <a href="new.swf"></a>
> <a href="flowers.swf"></a>
> <a href="grounds.swf"></a>
> <a href="books.swf"></a>
> <a href="christmascards.swf"></a>
> <!--text used in the movie-->
> <!-- saved from url=(0013)about:internet -->
> <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
> codebase=" http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#ve
> rsion=9,0,28,0" width="635" height="400">
> <param name="movie" value="slideshow.swf" />
> <param name="quality" value="high" />
> <embed src="slideshow.swf" quality="high"
> pluginspage=" http://www.adobe.com/shockwave/download/download.cgi?P1_Prod_Versio
> n=ShockwaveFlash" type="application/x-shockwave-flash" width="635"
> height="400">
> </embed></object>
> </body>
> </html>
2. Re: Embed tage not found durin Validation
INVT Mar 19, 2008 7:09 AM (in response to Newsgroup_User)
Do you know why if the embed tag is not valid why is it still implemented when you ad the flash object and why is it also added when you publish the html for the swf. Is there a work around to fix it or is not that big of a deal and just leave it alone. I have updated the software but its still adds the embed tag.
I know your just helping and I am not complaining and I appreciate your help. I did by the way fix my problem. I dropped the sideshow file into the directory through windows and it worked fine I really still don't know what the problem was but it works.
I am just a little concerned if the tag is not valid how do I fix or do I need to and will it effect all of my flash objects.
I know loaded question.
Emdedded
(just a little humor):)
3. Re: Embed tage not found durin Validation
Newsgroup_User Mar 19, 2008 8:28 AM (in response to Newsgroup_User)> Do you know why if the embed tag is not valid why is it still implemented
> when
> for
> the swf.
Some browsers do not support the <object>. It is required to use embed for
those browsers.
It's really not a big deal.
Yes - for reasons stated above.
news:frr6r8$g43$1@forums.macromedia.com...
> when
> for
> just
> tag.
> help.
> directory
> problem
> was but it works.
> need
> Emdedded
4. Re: Embed tage not found durin Validation
Newsgroup_User Mar 19, 2008 1:12 PM (in response to Newsgroup_User).oO(Murray *ACE*)
>> when
>> for
>> the swf.
>those browsers.
Yes, the really old ones. In IE 6 and all modern browsers the support
for the object element should be good enough.
Micha -
5. Re: Embed tage not found durin Validation
INVT Mar 19, 2008 1:51 PM (in response to Newsgroup_User)Thanks!
