So i was making my website using the like sample page template the dreamweaver gives you and i saved everything and restarted my pc and now it looks a lot different like before i had panels and stuff and now its all gone.
Like I said before, start over. Only this time do it right with a defined local site folder and immediately save your newly created starter page. Then DW will correctly save your assets and index page to your local site folder.
What you did was mess things up by 1) not defining a site and 2) not immediately saving your work to a folder on your hard drive. God only knows where your assets ended up.
Have you Defined a Site in DW?
That is a necessary first step: GS-01: Defining a new site
Without a Site Definition created and then chosen from your Files window dropdown menu, DW will do all sorts of strange things that will break links to .css and .js files. Those broken links will make pages that rely on css and javascript appear very broken.
If you mean DW's panels are missing, you can reset them under Window > Workspace Layout > Reset '-workspace name-'
No i didnt do a site definition is there still a way i can do that to get the site back to normal?
Where did you save your sample page and asset files?
Go to site > New Site > and tell DW where to find your files. Example, C:\\myFolder.
i think it is saved here but not sure how to get here cause i cant find the asset file
You should start over.
No I finished it and then I had to restart my PC and everything was messed up and looked plain when I came back
this is what it says
You have almost nothing on your page so far. Why don't you start over.
Define your site as Jon said.
Go to File > New > Startet Templates. Pick one and hit the Create button.
this is pretty much what is happening to me and the correct answer for that one has the link to fix it but dosnt work File not on local disk??
Ok so what I was using was the Starter Templates ----> Basic Layouts ---> basic - Single Page and now it looks nothing like that.
is it good like this?
