4 Replies Latest reply on Mar 19, 2008 4:17 PM by pjrich
    sequencing in functions
    pjrich
      I have a function that hides a horizontal rule, moves it relative to the currentTarget, and makes it reappear. The showEffect on the HR is an instance of the WipeRight effect, and the hideEffect is an instance of the WipeLeft effect. So, in essence, when a user clicks on a button, a line "grows" out of that button to the right. When a user clicks another button, the line "shrinks" from its current position, moves to the new position, and "grows" from there. At least, that was the plan. The problem is the the move occurs faster than the effect, and the line ends up EITHER turning visible or invisible, but not both, as planned. Here's the code for the function:
      quote:
      public function moveHideHRule(event:Event):void {
      myLine.visible = false;
      myLine.x = event.currentTarget.x + 135;
      myLine.y = event.currentTarget.y + 10;
      myLine.visible = true;
      here's where I call the event:
      quote:
      <mx:LinkButton id="addBtn" x="10" y="50" label="Add a New Resource"
      click="theWindow.selectedChild=myAdd; moveHideHRule(event);" />
      <mx:LinkButton id="updateBtn" x="10" y="80" label="Update a Resource"
      click="theWindow.selectedChild=myUpdate; moveHideHRule(event);"/>
      <mx:LinkButton id="searchBtn" x="10" y="110" label="Search for a Resource"
      click="theWindow.selectedChild=mySearch; moveHideHRule(event);"/>
      and here's where I create/call the effects:
      quote:
      <mx:HRule width="50" strokeWidth="1" strokeColor="blue"
      x="139" y="60" visible="false" id="myLine"
      showEffect = "{myRightWipe}" hideEffect="{myLeftWipe}"/>
        • 1. Re: sequencing in functions
          Sreenivas R Adobe Employee
          As you are setting the visible property to true and false in the same function the effects are not being played correctly.
          To give the effect you want use two HRules. Hide one and show another. Keep swapping their roles.
          • 2. Re: sequencing in functions
            Gregory Lafrance Level 6
            Need more complete sample code.
            • 3. Re: sequencing in functions
              dimpled
              You might want to make those a sequence effect:
              myLineEffect = new mx.effects.Move(myLine);
              myEffectSequence = new mx.effects.Sequence();
              myEffectSequence.addChild(myLineEffect);
              myEffectSequence.play();
              • 4. Re: sequencing in functions
                pjrich Level 1
                I've been able to create a Sequence effect, as suggested by dimpled, but it does not completely solve my problem. You see, I don't actually want to see myLine move (right now, I'm using a Move effect). I thought I might be able to get around this by embedding the move within a sequence in a function, but I can't seem to figure out how to embed other, non-effect, actions within a sequence. The best I can get is for the sequence to run and then myLine appears at the new spot, or vice versa.
                As Screenivas mentions, I could easily create two (or more) HRules and forget about the moving, but I'd like to figure out if there's a way to include non-effect actions within a sequence. Here's the new code (in it's entirety, as Greg asked for). You see that I can get a sequence to work, but I don't actually want to see the HRule move.
                quote:
                <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" xmlns:ns1="*">
                <mx:Script>
                <![CDATA[
                private function moveLine(e:Event):void {
                myMove.end();
                myMove.xTo = e.currentTarget.x + 145;
                myMove.yTo = e.currentTarget.y + 10;
                myMove.play();
                myLineMove.play();
                </mx:Script>
                <mx:Sequence id="myLineMove" target="{myLine}" >
                <mx:WipeLeft id="myWL" duration="500"/>
                <mx:Move id="myMove" />
                <mx:WipeRight id="myWR" duration="500"/>
                </mx:Sequence>
                <mx:Panel x="10" y="0" width="100%" height="90%" layout="absolute" title="Intro Panel" id="P_intro">
                <mx:Text x="10" y="24" text="What would you like to do?" width="229"/>
                click="theWindow.selectedChild=myAdd; moveLine(event);" />
                click="theWindow.selectedChild=myUpdate; moveLine(event);"/>
                click="theWindow.selectedChild=mySearch; moveLine(event);"/>
                <mx:ViewStack x="173" y="10" id="theWindow" width="100%" height="95%">
                <mx:Panel id="starterPanel" borderColor="blue">
                <mx:Text text="Welcome!" id="welcomeMsg" x="45" y="78"/>
                </mx:Panel>
                <ns1:addRecord id="myAdd" />
                <ns1:searchForm id="myUpdate" />
                <ns1:updateRecord id="mySearch" />
                <mx:Canvas label="Add" width="100%" height="100%">
                </mx:Canvas>
                </mx:ViewStack>
                x="139" y="60" visible="false" id="myLine" />
                </mx:Panel>
                </mx:Application>
