1 Reply Latest reply on Jun 29, 2018 1:18 PM by twaritar3263062
    Image Help!
    danielleh10865397
      HI-
      I licensed the following image: #23941310  and would like to use it in InDesign on a colored background.  When I place it on the background, it has a white square around it.  I do not want the white square, I simply want the black image.  In the application, I have selected the image and clicked on 'Layers' and the image is a single layer, there is now 'background' layer to the image.  How can I remove the white square from the image?
      Thank you!!
      Danielle
        • 1. Re: Image Help!
          twaritar3263062 Adobe Employee
          Hi Danielle,
          Thanks for reaching out to the Stock community.
          I see you have downloaded a JPG file and the requirement you have cannot be achieved with this. JPG does not support transparency.  You need to find a PNG file.
          However, I have shared the workaround below in order to achieve the desired result.
          • Trace the file in Illustrator CC and then go to file and select the export option.
          You may also refer to How to edit artwork in Illustrator using Image Trace
          • Export the file as PNG as shown in the screenshot below:
          • Then go to Indesign and place the image in Indesign.
          Hope this helps!
          Please let us know if you have any additional questions.
          Regards,
          Twarita
