This content has been marked as final.
Show 1 reply
1. Re: Server not accepting connections
jheycie Mar 23, 2008 10:52 PM (in response to scr)Were you able to connect to this website before using this machine?
If you are using the same machine, try switching your settings to Passive FTP.
You can find this option when you recreate the connections...on the prompt where it is asking for your FTP information, click on the advance tab and select FTP settings manually. Then unchecked performance optimization and select Passive FTP.
If the above suggestion does not work, try following the suggestions on this tech note.
http://www.adobe.com/go/tn_16592
