This content has been marked as final.
Show 4 replies
1. Re: Unable to access a Remote Object
riesvantwisk Mar 18, 2008 9:11 AM (in response to Anand_Wipro)it looks like that the backend cannot find your class. Did you put the generated jar file in your lib directory??
Also, check your remoting-config.xml file if you did setup your destination properly, specially your source. And check if your services-config.xml file has a include for remoting-config.xml.
I made a blaze-ds (blaze-ds with remoting and messeging with ant as the build tool) example which can be downloaded here: http://www.vantwisk.nl/riesvantwisk/entry/adobe_flex_and_blaze_ds
Ries -
2. Re: Unable to access a Remote Object
Anand_Wipro Mar 18, 2008 9:00 PM (in response to riesvantwisk)Hi riesvantwisk ,
Many thanks for your response. But just to confirm, i have my remoting-config.xml and services-config.xml properly configured with the channel definition and destination information correctly. Just to update you that i have few other Remote Object calls that are been made to this remoting-config.xml and they work perfectly fine. The only important difference between these two RO calls is that for the successful RO call, the required Remote Object class is available as part of a JAR file in my EAR. But in case of the Unsuccessful RO call, the required Remote Object class is actually available in the WAR itself as part of WAR/WebContent/WEB-INF/classes.
All other configuration information apart from this difference are literally the same for both the Remote Object calls.
Once again many thanks for your response. -
3. Re: Unable to access a Remote Object
riesvantwisk Mar 19, 2008 7:27 AM (in response to Anand_Wipro)I had the exact same problem. I solved it to change my application from a ear deployment to a war deployment. This was when I was using JBoss.
The people on the JBoss channel tried to explain me but you need to make profisions to make the jar available 'at some point'
Unfortunately I am not extremely knowledgable in that area and I cannot really help you to solve using a ear deployment, just that I know about the problem and it has something todo how ear deployments work.
So for me it was simple and I changed it to .war :)
ries
4. Re: Unable to access a Remote Object
Anand_Wipro Mar 19, 2008 9:37 PM (in response to riesvantwisk)Many thanks for your response. But unfortunately i have to deploy into an EAR and then run the application. Let me see if i can solve it in some other means.
Thanks again.
