2 Replies Latest reply on Mar 14, 2008 7:46 AM by luciewong
    wired Transition "blinds"
    luciewong Level 1
      I have an empty MovieClip which loads an image in.
      I dont want the image visible on start.
      So I attach a MC from the library as quasi cover over the image.
      When all is loaded, I want the cover (attached MC) dissappear
      with the "blinds" transition, so the image under it is then visible.
      The Problem is, the Cover clip always starts OPEN, so the image is visible on start and then closes, covering the Image.
      I have changed >direction:Transition.IN< or >Transition.OUT<
      but always same effect!!
      Thanks for any help.
      var mc3 = cover_mc;
      var TweenBlinds = new mx.transitions.TransitionManager.start(mc3, {type:mx.transitions.Blinds, direction:Transition.IN, duration:transTime, easing:None.easeNone, numStrips:15, dimension:0});
