3 Replies Latest reply on Jul 3, 2018 1:59 PM by shmunzlerin
    Lightroom Vorgabe - Gruppe erstellen
    shmunzlerin
      Ich möchte in Lightroom in den Vorgaben eine neue Gruppe erstellen.
      Normalerweise habe ich das mit Rechtsklick in den Vorgaben-Bereich getan.
      Wenn ich das allerdings jetzt am neuen Rechner mache, steht da nur "Ausgeblendete Vorgaben zurück setzen"
      Was kann ich tun?
        • 1. Re: Lightroom Vorgabe - Gruppe erstellen
          Sahil.Chawla Adobe Employee
          Hi Shmunzlerin,
          I'm not sure if I understand the issue correctly, could you please explain the issue a bit more? and share your complete work flow, as we need some more information to help you our further.
          Regards,
          Sahil
          • 2. Re: Lightroom Vorgabe - Gruppe erstellen
            johnrellis Most Valuable Participant
            Google translation: Lightroom Default - Create Group. I want to create a new group in Lightroom in Preferences. Normally I have done this with right-click in the preferences area. However, if I do that now on the new computer, there is only "reset hidden preferences" What can I do?
            LR 7.3 makes this harder and obscure -- you need to create a dummy preset:
            1. In the Presets panel, click + and then Create Preset.
            2. In the Create Preset window, click User Presets
            3. Select New Group and enter the name of your group:
            4. Click Create to create the preset.
            5. Drag one or more presets into the new group.  Only then can you delete the dummy preset -- otherwise the group will disappear when it contains no presets!
