• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
30.25 FPS
Community Beginner ,
Jul 06, 2018 Jul 06, 2018
I just got a new phone and strangly enough it records video at 1080p @ 30.25 fps, when I import this to Premiere @ 30fps, every second, 0.25 frames are lost, thus every 4 seconds I loose a frame which leads to audio and video sychcronization. Does anyone know what to do?
Thanks!
Views
425
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 07, 2018 Jul 07, 2018
You cannot.
That is how your phone operates.
Or get a regular videocamera.
Run the file through Handbrake and set it to constant framerate if you have audio issues on the timeline.
Votes
Translate
Translate
LEGEND ,
A frame-rate like that actually most likely indicates that it is using VFR (variable frame-rate) recording, as do most phones. So the frame-rate varies per second throughout clips. The 'average' rate will be reported as the clip's frame-rate by PrPro.
And ... you can't lose a quarter of a frame. It will either re-rate the speed slightly or occasionally dump a frame.
Neil
Votes
Translate
Translate
Report
Report
Oh, I see, it is quite complicated but how can I avoid the non sychronization then?
Votes
Translate
Translate
Report
Report
Community Expert ,
You cannot.
Votes
Translate
Translate
Report
Report
Thanks, it is a bit of a pain in the back to have to put the video through that everytime, especially if it is a long video, but at least it works
Thanks again!!
Votes
Translate
Translate
Report
Report
Managed to fix it, thanks!!
Votes
Translate
Translate
Report
Report
LEGEND ,
The latest 2018 PrPro can work fairly well with most VFR media, but not perfectly with all phones/devices that produce it. So, when that strikes, it's still best to do as Ann suggests and use Handbrake to convert. You can batch-convert in Handbrake and say do it over-night so you don't waste time sitting there while it's converting.
I'll include my personal settings for Handbrake such that you both get it converted and keep the best file-integrity at the other end.
Note that I've red-ticks by ​both​ the radio-box Constant Framerate button ​and​ a specific number in the FPS box ... you have to have both ​a​ number and the box. The box checked and 'auto' or anything other than a number, you'll still get the original VFR out.
Also, I go with at least the 4.2 on Encoder Level, though I've played with going to 5 on occasion. But this will result in files with nearly the same or slightly higher bit-rates than the original, avoiding re-compressing at a higher rate.
Neil
Votes
Translate
Translate
Report
Report
Enthusiast ,
Jul 08, 2018 Jul 08, 2018
LATEST
With version 12.1.1 you should not have problems with those files.
Votes
Translate
Translate
Report
Report
