0 Replies Latest reply on Mar 28, 2008 12:31 PM by MattFlex3
    Calendar Property
    MattFlex3 Level 1
      Hello, I wanted to ask on the basis of this code, a timetable, as I show that I only work days, because when I click the button week shows me a day where I am 7 days ahead.
      package
      import qs.*;
      import mx.*;
      import sjd.*;
      public class app_code extends Application
      public function app_code()
      super();
      calLoader = new HTTPService();
      calLoader.resultFormat = "text";
      [Bindable] public var calSet:CalendarSet = new CalendarSet();
      protected static const displayOptions:Array = ['month','week','day']
      public var calLoader:HTTPService;
      public var calUrl:TextInput;
      [Bindable] public var displayMode:ToggleButtonBar;
      [Bindable] public var cal:CalendarDisplay;
      public var chooser:DateChooser;
      public var busy:Busy;
      protected function addCalendar():void
      { var createDlg:CreateCalendarDialog = new CreateCalendarDialog();
      createDlg.loadCallback = function(dlg:CreateCalendarDialog):void
      { loadCalendar(dlg.url,dlg.calendarName,dlg.color); }
      PopUpManager.addPopUp(createDlg,this,true);
      PopUpManager.centerPopUp(createDlg); }
      protected function load():void
      ToolTipManager.toolTipClass = HtmlToolTip;
      cal.range = new DateRange(chooser.selectedDate,chooser.selectedDate);
      loadCalendar("data/test.ics","default",0xBB0000);
      private function loadCalendar(url:String, name:String, color:uint):void
      { busy.currentState = "busy";
      url = URLUtil.getFullURL(systemManager.loaderInfo.url,url);
      calLoader.url = url + "?" + Math.random();
      var token:AsyncToken = calLoader.send();
      token.addResponder(new Responder(
      function(param:*):void {
      var calData:String = (token.result as String);
      var p:iParser = new iParser();
      var calendar:Calendar = p.parse(calData)[0];
      calendar.contextColor = color;
      calendar.name = name;
      calSet.calendars = calSet.calendars.concat([calendar]);
      cal.dataProvider = calSet.events;
      busy.currentState = "free";
      }, function (param:*):void {
      Alert.show("calendar load failed");
      busy.currentState = "free"; })); }
      protected function goToToday():void
      { cal.range = new DateRange(new Date(),new Date()); }
      protected function formatDate(d:Date):String
      { var r:String = d.toDateString();
      return r; }
      public function removeCalendar(cal:Object):void
      { var cals:Array = calSet.calendars.concat();
      for(var i:int = 0;i<cals.length;i++)
      { if(cals == cal)
      { cals.splice(i,1);
      calSet.calendars = cals;
      return; } } }
      protected function updateRange():void
      { cal.displayMode = "auto";
      if(chooser.selectedRanges.length == 0)
      return;
      var selRange:Object = chooser.selectedRanges[0];
      cal.range = new DateRange(selRange.rangeStart,selRange.rangeEnd); }
      protected function rangeChangeHandler():void
      { chooser.selectedRanges = [ {rangeStart: cal.range.start, rangeEnd: cal.range.end} ];
      chooser.displayedYear = cal.range.start.fullYear;
      chooser.displayedMonth = cal.range.start.month; }
      protected function displayModeHandler():void
      { switch(cal.displayMode)
      case "day":
      case "days":
      displayMode.selectedIndex = 2;
      break;
      case "week":
      case "weeks":
      displayMode.selectedIndex = 1;
      break;
      case "month":
      default:
      displayMode.selectedIndex = 0;
      break; } }
      protected function headerClickHandler(d:Date):void
      cal.range = new DateRange(d,d); }
      protected function dayClickHandler(d:Date):void
      protected function displayModeItemClickHandler():void
      { cal.displayMode=displayOptions[displayMode.selectedIndex]; }
      protected var _colors:Array = [
      0xBB0000,
      0x00BB00,
      0x0000BB,
      0xBBBB00,
      0xBB00BB,
      0x00BBBB
      public function addCalendarDialog(start:Date, end:Date, allDay:Boolean):void
      { var createDlg:IFlexDisplayObject = new AddCalendarEventDialog();
      AddCalendarEventDialog(createDlg).startDate = start;
      AddCalendarEventDialog(createDlg).endDate = end;
      AddCalendarEventDialog(createDlg).addDayCallback = addCalendarDay;
      AddCalendarEventDialog(createDlg).addTimeCallback = addCalendarTime;
      var startNum:Number = 0;
      var endNum:Number = 0;
      if(allDay){ startNum = 0;
      endNum = 23.5; }else{
      startNum = start.hours;
      endNum = end.hours;
      if(start.minutes > 0){
      startNum += 0.5;
      if(end.minutes > 0){
      endNum += 0.5;
      AddCalendarEventDialog(createDlg).startDateUI.selectedDate = start;
      AddCalendarEventDialog(createDlg).endDateUI.selectedDate = end;
      AddCalendarEventDialog(createDlg).timeUI.values = [startNum, endNum];
      callLater(AddCalendarEventDialog(createDlg).refresh);
      public function editCalendarDialog(event:CalendarEvent):void{
      var createDlg:IFlexDisplayObject = new EditCalendarEventDialog();
      EditCalendarEventDialog(createDlg).cd = cal;
      EditCalendarEventDialog(createDlg).event = event;
      if(event.allDay){
      startNum = 0;
      endNum = 23.5;
      }else{
      startNum = event.start.hours;
      endNum = event.end.hours;
      if(event.start.minutes > 0){
      startNum += 0.5;
      if(event.end.minutes > 0){
      endNum += 0.5; } }
      EditCalendarEventDialog(createDlg).timeUI.values = [startNum, endNum];
      callLater(EditCalendarEventDialog(createDlg).refresh);
      public function addCalendarDay(start:Date, end:Date, summary:String, description:String = "", color:Number = 0):void{
      if(DateUtils.toIcsDate(start) == DateUtils.toIcsDate(end)){
      return;
      }else{
      end.date += 1;
      description = StringUtils.replaceAll(description, "\n", "\\n");
      description = StringUtils.replaceAll(description, "\r", "\\n");
      var now:Date = new Date();
      "BEGIN:VCALENDAR\r\n"+
      "PRODID:-//Google Inc//Google Calendar 70.9054//EN\r\n"+
      "VERSION:2.0\r\n"+
      "CALSCALE:GREGORIAN\r\n"+
      "METHOD:PUBLISH\r\n"+
      "X-WR-CALNAME:test cal\r\n"+
      "X-WR-TIMEZONE:America/Los_Angeles\r\n"+
      "X-WR-CALDESC:\r\n"+
      "BEGIN:VEVENT\r\n"+
      "DTSTART;VALUE=DATE:"+DateUtils.toIcsDate(start)+"\r\n"+
      "DTEND;VALUE=DATE:"+DateUtils.toIcsDate(end)+"\r\n"+
      "DTSTAMP:"+DateUtils.toIcsDate(now) + "T" + DateUtils.toIcsTime(now)+"Z\r\n"+
      "ORGANIZER;CN=test cal:MAILTO:0vpmlit9621663ap27ilpg4hr0@group.calendar.goog\r\n"+
      " le.com\r\n"+
      "UID:cagcjos8b9sd7641vbk6mcv708@google.com\r\n"+
      "CLASS:PRIVATE\r\n"+
      "CREATED:"+DateUtils.toIcsDate(now) + "T" + DateUtils.toIcsTime(now)+"Z\r\n"+
      "LAST-MODIFIED:"+DateUtils.toIcsDate(now) + "T" + DateUtils.toIcsTime(now)+"Z\r\n"+
      "SEQUENCE:1\r\n"+
      "STATUS:CONFIRMED\r\n"+
      "DESCRIPTION:"+description+"\r\n"+
      "SUMMARY:"+summary+"\r\n"+
      "TRANSP:OPAQUE\r\n"+
      "END:VEVENT\r\n"+
      "END:VCALENDAR";
      calendar.name = "name";
      public function addCalendarTime(start:Date, end:Date, summary:String, description:String = "", color:Number = 0):void{
      "VERSION:2.0\r\n"+
      "BEGIN:VEVENT\r\n"+
      "DTSTART;TZID=America/Los_Angeles:" + DateUtils.toIcsDate(start) + "T" + DateUtils.toIcsTime(start)+"\r\n"+
      "DTEND;TZID=America/Los_Angeles:" + DateUtils.toIcsDate(end) + "T" + DateUtils.toIcsTime(end)+"\r\n"+
      " le.com\r\n"+
      "UID:j1o618k1tklj779nu2kgj9560s@google.com\r\n"+
      "CREATED:20060907T165444Z\r\n"+
      "LAST-MODIFIED:20060907T165444Z\r\n"+
      "LOCATION:\r\n"+
      "SEQUENCE:0\r\n"+
      "END:VEVENT\r\n"+
      "END:VCALENDAR";
