10 Replies Latest reply on Sep 20, 2018 11:54 AM by Test Screen Name
    Install Adobe Flash Player
    ramyw33420179 Level 1
      Welcome to the team I have downloaded the latest version but when I play I have a lot of problems and be very slow and I can not play and I have continued with the support of the game and told me that the problem is not them .. But the latest version of you ... I hope you know the best news for the issuance of online games
        • 1. Re: Install Adobe Flash Player
          maria__ Adobe Employee
          The performance issue you are experiencing is most likely due to a security fix implemented in Flash Player 30.  See Spectre/Meltdown Mitigation section of the Flash Player 30 Release Notes, including information on a work-around.
          Maria
          • 2. Re: Install Adobe Flash Player
            Where is this section that I can not find in the list of comments Please insert it here
            • 3. Re: Install Adobe Flash Player
              Spectre / Meltdown Mitigations
              In response to a class of recently disclosed vulnerabilities in popular CPU hardware related to data cache timing (CVE-2017-5753, CVE-2017-5715, CVE-2017-5754), known popularly as Spectre and Meltdown, we are disabling the ‘shareable’ property of the ActionScript ByteArray class by default.  Administrators can turn this feature back on using the following MMS properties:
              EnableInsecureByteArrayShareable
              Short Description:
              Allows Administrators to override the Flash Player 30 and above default behavior of restricting the “shareable” property of the ActionScript ByteArray API class.
              Detailed Description:
              EnableInsecureByteArrayShareable = [0,1] (0=false, 1=true)
              This setting will allow Administrators to override the Flash Player 30 and above default behavior of restricting the “shareable” property of the ActionScript ByteArray API class. Shared ByteArrays are used to share data between threads with ActionScript “Workers.” Shared ByteArrays are an advanced feature of the ActionScript API set and not commonly used in the vast majority of published Flash content. For increased security, we recommend administrators leave this feature disabled.
              EnableInsecureByteArrayShareableDomain
              Short Description:
              Allows Administrators to override the Flash Player 30 and above default behavior of restricting the “shareable” property of the ActionScript ByteArray API class on a per-domain basis.
              EnableInsecureByteArrayShareableDomain = domain name or IP address
              By default, Flash Player 30 and above will no longer allow the “shareable” property of the ActionScript ByteArray API class. The EnableInsecureByteArrayShareableDomain settings provide exceptions to that rule. Administrators can create a “white list” of approved domain names or IP addresses to which the EnableInsecureByteArrayShareable setting will apply. If the active security context is in the list of domains and IP addresses, then access to the sharable ByteArray property will be allowed. Otherwise, sharable ByteArray access will be denied.
              For domain names, prefixing a * wildcard is allowed. For example, *.adobe.com would allow all Flash content with the “shareable” property to run on www.adobe.com, get.adobe.com, helpx.adobe.com, and so on. Wildcards are not allowed when specifying IP addresses.
              For example, the following settings allow SWFs using the shareable ByteArray property to only run on servers at www.mydomain.com and 10.1.1.10:
              EnableInsecureByteArrayShareableDomain=www.mydomain.com
              EnableInsecureByteArrayShareableDomain=10.1.1.10
              Example:
              EnableInsecureByteArrayShareableDomain=*.mydomain.com
              This would allow all Flash content with the “shareable” property to run on www.mydomain.com, foo.mydomain.com, and so on. Wildcards are not allowed when specifying IP addresses.
              EventJitterMicroseconds
              Setting this value to 0 disables an important mitigation for Spectre and Meltdown (CVE-2017-5753, CVE-2017-5715, CVE-2017-5754) style attacks, but may improve application performance in some limited circumstances.
              TimerJitterMicroseconds
              For information on managing the mms.cfg file, please see the Flash Player System Administrator's guide, here: http://www.adobe.com/devnet/flashplayer/articles/flash_player_admin_guide.html
              • 4. Re: Install Adobe Flash Player
                For summary on editing the mms.cfg file see Editing the mms.cfg file
                • 5. Re: Install Adobe Flash Player
                  Well ... I found this file what I would do by asking for more clarification
                  • 6. Re: Install Adobe Flash Player
                    Not sure what you mean.
                    While we provide the ability to disable the security mitigation, this is a work-around isn't really recommended as it disables the security measures implemented.  Ideally, the content provider fixes their content to work-around this change.
                    • 7. Re: Install Adobe Flash Player
                      I've found the mms.cfg file what I will do next
                      • 8. Re: Install Adobe Flash Player
                        What you need to do before proceeding is understand the consequences of turning off security fixes. It's like choosing not to lock your car or house because you are fed up of carrying keys around. Do you know the risks and accept them? Do you ever use the same computer for personal information or shopping?
                        • 9. Re: Install Adobe Flash Player
                          andréb70868408
                          Dear ramyw33420179,
                          As a 89 yr. old man, i have a lot of difficulty with Tech..
                          So, would you install "adobe Flash Player for me?-
                          Andre Belanger
                          [email removed by  forum moderator]
                          • 10. Re: Install Adobe Flash Player
                            No, I won't, and you should not trust ANYONE you meet online who offers to make things happen on your computer. Find a friend or a shop. Otherwise, sorry to say, bad things will happen to your computer.
