2 Replies Latest reply on Jul 11, 2018 3:37 PM by dhiraja75994382
    AEM Search Pages and Asset References in one result
    dhiraja75994382 Level 1
      I have assets which have some metadata. I am performing a full text search on my pages and also on my assets (/content and /content/dam). This result returns me the dam:Asset as well as cq:Page. But instead of the assets, I wanted to have the pages in which these assets are referenced. If there an out of the box way or query i can use to get the pages as well as the pages where these matching assets are referenced?
      If you can help me join below two queries -
      select * from [dam:Asset] as parent where contains(*, 'abcd') and isdescendantnode(parent, '/content/dam')
      select * from [cq:Page] as child where contains(*, {parent asset path})
      If the above is achieved i can do a union with below query
      select * from [cq:Page] as a where contains(*, 'abcd') and isdescendantnode(a, '/content/')
      I am following below approach to achieve this but I face issue with pagination. - setting offset and limit as I am manipulating the search results. - the asset references can either be 0 or 100 and I add this to my search results.
      predicates.put("group.p.or", "true"); // combine this group with OR
      predicates.put("group.1_group.path", "/content/");
      predicates.put("group.1_group.type", "cq:Page");
      predicates.put("group.2_group.path", "/content/dam/");
      predicates.put("group.2_group.type", "dam:Asset");
      predicates.put(LIMIT, String.valueOf(params.getLimit()));
      predicates.put(OFFSET, String.valueOf(params.getOffset()));
      Predicate fulltextSearch = new Predicate(FulltextPredicateEvaluator.FULLTEXT);
      fulltextSearch.set(FulltextPredicateEvaluator.FULLTEXT, params.getSearchText());
      query.getPredicates().add(fulltextSearch);
      SearchResult results = query.getResult();
      List<Node> nodes = new ArrayList<>();
      Iterator<Node> it = results.getNodes();
      while (it.hasNext()) {
        Node result = it.next();
        try {
         if (result.getPath().contains("/content/dam")){
        nodes.addAll(assetReferences.getAssetReferences(result.getPath().replace("/jcr:content/metadata","")));
        } catch (RepositoryException e) {
         LOGGER.error(e.getMessage());
      List<Node> searchResults = Lists.newArrayList(results.getNodes());
      searchResults.addAll(nodes);
      Asset References
      public List<Node> getAssetReferences(final String assetPath){
         ReferenceSearch referenceSearch = new ReferenceSearch();
         referenceSearch.setExact(true);
         referenceSearch.setHollow(false);
         referenceSearch.setMaxReferencesPerPage(-1);
         Collection<ReferenceSearch.Info> resultSet = referenceSearch.search(resolver, assetPath).values();
        for (ReferenceSearch.Info info: resultSet) {
        nodes.add(info.getPage().adaptTo(Node.class));
         return nodes;
        • 1. Re: AEM Search Pages and Asset References in one result
          Arun Patidar Level 4
          No need to do fulltext search just search for assets based on meatdata.
          1. Get all the assets which met metadata criteria, for example
          path=/content/dam/AEM63Lab/
          type=nt:unstructured
          nodename=metadata
          property=dc:title
          property.value=cisco
          2. From the result get the assets path and store in array list or Array.
          3. loop through array/arrayList and get all the page references for assets one by one using below code.
          ReferenceSearch rr = new ReferenceSearch();
          Map map = rr.search(request.getResourceResolver(),assetPath);
          If you want to use pagination for assets you can always use limit, offset with guesstotal.
          Query Builder API
          If you want to use pagination for Pages, you can handle this with Java once you have results in resultSets you can use resultSet however you want.
          java - How to implement pagination on a list? - Stack Overflow
          Please let us know the exact requirement if it doesn't help.
          Arun
          • 2. Re: AEM Search Pages and Asset References in one result
            So my properties are not defined for metadata. it could be multiple properties where the text matches, hence doing a full text search.
            Secondly, I am searching for assets and pages together. out of the assets returned, i am fetching their references(pages) and returning these as well. Hence the issue with query builder pagination.
            Third, I don't want to create the entire list in one shot as this may be a slow query and implement pagination using java.
