11 Replies Latest reply on Jul 16, 2018 3:36 AM by Laubender
    Auto vertical and horizontal Align script
    jarosławz53072541 Level 1
      First of all - I'v maded few hours of search (this forum and google).
      I was found script which is almost doing what i want: Peter Kahrel -- Free script | Align objects
      But i would like to have easier (faster) scirpt:
      What i would like to have:
      I would like select 2 objects - and by one click align them vertical and horizontl.
      Default using Adobe tool i must always make two clicks for both options.
      Do you know maybe how i can do that?
      Best Regards
      Jarek
        • 1. Re: Auto vertical and horizontal Align script
          BarlaeDC Adobe Community Professional
          I know this is not a scripting solution but in CC 2018 (I haven't checked other versions) if you use quick apply - it defaults to the align options when you have 2 or more objects selected, that is just Cmd(Ctrl) + Return and then type or click to get the one you want, I don't' see a script making it much faster than that, but it maybe someone on here has a faster solution.
          Regards
          Malcolm
          • 2. Re: Auto vertical and horizontal Align script
            Michel [FRIdNGE] Level 4
            Maybe I'm wrong! …
            According to me, there're 9 configurations [alignments, no distributions]!
            So 9 simplistic 2-lines scripts, whose name is associated to a number of the keypad!
            7 8 9
            4 5 6
            1 2 3
            … so, e.g., "horizontal-centers alignment + vertical-centers alignment" would be:
            app.activeDocument.align (app.selection, AlignOptions.HORIZONTAL_CENTERS);
            app.activeDocument.align (app.selection, AlignOptions.VERTICAL_CENTERS);
            Its name: 5_H-Center--V-Center.jsx
            I could give you the 8 other scripts but I'm too lazy for that!
            Welcome to the party!
            Best,
            Michel, For FRIdNGE
            • 3. Re: Auto vertical and horizontal Align script
              S Hopkins Adobe Community Professional
              Here is the script for AppleScript:
              tell application "Adobe InDesign CC 2018"
                set selList to selection --assumes more than one item selected
                tell document 1
                align align distribute items selList align option horizontal centers
                align align distribute items selList align option vertical centers
                end tell
              end tell
              Put the script with your scripts in the Scripts panel and give it a keyboard shortcut (maybe Command + Shift + A) for one-stroke functionality. Keyboard Shortcuts are found under Edit in InDesign's menu.
              • 4. Re: Auto vertical and horizontal Align script
                So they end up on top of each other, centered on the center point? If that is not what you mean, show a "before/after" image.
                • 5. Re: Auto vertical and horizontal Align script
                  https://forums.adobe.com/people/Michel+%5BFRIdNGE%5D  wrote
                  … Welcome to the party!
                  Hi Michel,
                  see also into method distribute() and property selectionKeyObject of object Document.
                  Regards,
                  Uwe
                  • 6. Re: Auto vertical and horizontal Align script
                    Thanks to Peter Kahrel who made this one  Peter Kahrel -- Free script | Align objects
                    I was ask him is there any chance to make modification.
                    So he did it - and i'm very helpfoul for him.
                    So - what i maded with this? I was created shortcut CTRL+SHIFT+C and attached script:
                    And now what i have ?:D
                    When i select two object's i can simply pres shorcut described above and have aligned two objects
                    Mr. Peter Kharel - thank you for all - Your are Amazing!!!
                    (BTW: First selected object is "key object")
                    // DESCRIPTION Align frames CorelDraw-style: last selected frame is target
                    // Peter Kahrel
                    var obj = app.selection;
                    if( obj.length < 2 ) {
                    errorM('Select at least two objects');
                    function errorM( m ){
                    alert( m );
                    exit()
                    function getPosition( o, pos ) {
                    switch( pos ) {
                    case 'top' : return o.geometricBounds[0];
                    case 'left' : return o.geometricBounds[1];
                    case 'bottom' : return o.geometricBounds[2];
                    case 'right' : return o.geometricBounds[3];
                    case 'hcentre' : return o.geometricBounds[1] +
                    ((o.geometricBounds[3] - o.geometricBounds[1]) / 2);
                    case 'vcentre' : return o.geometricBounds[0] +
                    ((o.geometricBounds[2] - o.geometricBounds[0]) / 2);
                    function align_hor( obj, source_align, target_align ){
                    var target = getPosition( obj[0], target_align )
                    for( var i = 1; i < obj.length; i++ ) {
                    obj[i].move( undefined, [target - getPosition(obj[i],source_align), 0], true );
                    function align_vert( obj, source_align, target_align ){
                    [0, target - getPosition(obj[i],source_align)], true )
                    function alignFrames (type) {
                    switch (type) {
                    // horizontal alignment
                    case 'RL' : align_hor( obj, 'right', 'left'); break;
                    case 'RC' : align_hor( obj, 'right', 'hcentre'); break;
                    case 'RR' : align_hor( obj, 'right', 'right'); break;
                    case 'CL' : align_hor( obj, 'hcentre', 'left'); break;
                    case 'CCH' : align_hor( obj, 'hcentre', 'hcentre'); break;
                    case 'CR' : align_hor( obj, 'hcentre', 'right'); break;
                    case 'LL' : align_hor( obj, 'left', 'left'); break;
                    case 'LC' : align_hor( obj, 'left', 'hcentre'); break;
                    case 'LR' : align_hor( obj, 'left', 'right'); break;
                    // vertical alignment
                    case 'BT' : align_vert( obj, 'bottom', 'top'); break;
                    case 'BC' : align_vert( obj, 'bottom', 'vcentre'); break;
                    case 'BB' : align_vert( obj, 'bottom', 'bottom'); break;
                    case 'CT' : align_vert( obj, 'vcentre', 'top'); break;
                    case 'CCV' : align_vert( obj, 'vcentre', 'vcentre'); break;
                    case 'CB' : align_vert( obj, 'vcentre', 'bottom'); break;
                    case 'TT' : align_vert( obj, 'top', 'top'); break;
                    case 'TC' : align_vert( obj, 'top', 'vcentre'); break;
                    case 'TB' : align_vert( obj, 'top', 'bottom'); break;
                    default : errorM('Illegal input.')
                    alignFrames ('CCH');
                    alignFrames ('CCV');
                    //~ function alignType(){
                    //~ var dlg = app.dialogs.add( { name: 'Align' });
                    //~ with( dlg.dialogColumns.add() )
                    //~ with( borderPanels.add() )
                    //~ var userSelect = textEditboxes.add( { editContents : 'CCH' } );
                    //~ if( dlg.show() )
                    //~ var temp = userSelect.editContents;
                    //~ dlg.destroy();
                    //~ return temp;
                    //~ else
                    //~ dlg.destroy();
                    //~ exit();
                    So we can close ticket as it is fixed
                    • 7. Re: Auto vertical and horizontal Align script
                      So this might by good script - but in windows isn't work
                        tell document 1
                        end tell
                      end tell
                      • 8. Re: Auto vertical and horizontal Align script
                        It's greate! but - objects are moving from place.
                        I was posted script maded by: Peter Kahrel which is more useful.
                        But thank you for advice It's pretty nice to recive some help.
                        • 9. Re: Auto vertical and horizontal Align script
                          … but - objects are moving from place.
                          Hi Jaroslaw,
                          they do because there is no selectionKeyObject in the selection.
                          And it is also not defined in the script by Michel. Assumption: Neither it is defined by the user, you.
                          Michel's script run on two objects selected where no selectionKeyObject is applied to the selection:
                          If Michel's script would work with selectionKeyObject and selectionKeyObject would have been defined by the user with an extra click:
                          Note: method align() has 4 arguments that are relevant if there is a selectionKeyObject.
                          If there is and you are using Michel's script it will throw an error message.
                          Here a different version of Michel's script that is working with or without a selectionKeyObject:
                          ( function()
                              app.scriptPreferences.userInteractionLevel = UserInteractionLevels.INTERACT_WITH_ALL;
                              app.doScript
                                  alignCenterCenter,
                                  ScriptLanguage.JAVASCRIPT,
                                  UndoModes.ENTIRE_SCRIPT,
                                  "Align Selection Center-Center | SCRIPT"
                              function alignCenterCenter()
                                  if( app.documents.length == 0 ){ return };
                                  if( app.selection.length < 2 ){ return };
                                  var doc = app.activeDocument;
                                  if( doc.selectionKeyObject == null )
                                      doc.align(  app.selection , AlignOptions.HORIZONTAL_CENTERS );
                                      doc.align(  app.selection , AlignOptions.VERTICAL_CENTERS );
                                      return;
                                  doc.align( app.selection , AlignOptions.HORIZONTAL_CENTERS , AlignDistributeBounds.KEY_OBJECT , doc.selectionKeyObject );
                                  doc.align( app.selection , AlignOptions.VERTICAL_CENTERS , AlignDistributeBounds.KEY_OBJECT , doc.selectionKeyObject );
                          Regards,
                          Uwe
                          • 10. Re: Auto vertical and horizontal Align script
                            Thank you But Peter script automatically set "key object" as first selected item.
                            So there isn't necessary to choose from panel align "key object" simply this making script maded by Peter.
                            • 11. Re: Auto vertical and horizontal Align script
                              Hi Jaroslaw,
                              the one above could be useful if you selected all objects you want to align and did not make up your mind or you changed your mind on the object you want the others align to. :-)
                              Best,
                              Uwe
