I would like to solve a problem
reading the various posts I did not find solutions
I photograph sports events
and I create postcards
entering team data and player years
since I photograph the same events every year
I would like to change the players' years by adding one more year
for example if the player is 14 years old
the script automatically has to add me a year then 15
before
after
Add date variable to a code so every next year script will compare that date with current date. If there is one is one or more years difference between them, it is going to increase appropratielly age value on each card you process. You may also have only one card and one .txt fie with many ages from some year. It's going to use only card image and read ages one by one to increase them of calculated ammount. Perfect would be to know exact date of birth of your clients you put to that .txt file, so if you used second method it won't just add another year(s) to previous age value, but will be checking how old some one is to enter certain person age.
