17 Replies Latest reply on Jul 17, 2018 6:36 PM by jordanwalkert
    Audio Sync Issue on MiniDV Tape Capture
    jordanwalkert Level 1
      I have several MiniDV tapes I am trying to capture from a Panasonic DVX100 into latest version of Premiere CC, I have also tried in Premiere 2017. I am on the latest iMac with the newest version of OSX. I am doing a log and capture method in the shortest scene by scene capture that I can, but it seems the longer I try to capture the more the audio slowly begins to drift out of sync. The tapes are all 16 bit 48K audio, 24p, and my project reflects that. I found another 3rd party app called Vidi that captures the entire tape perfectly with no sync issues the entire time, but it can only do so in the .dv file format which is not supported by the latest version of Premiere or DaVinci Resolve and I don’t want to convert them to MOV because I’m trying to do a lossless workflow for archive purposes. Surely there has got to be a way to capture in premiere as back in the day I have captured over 1000 hours using this exact same method, camera, tapes! I feel like it’s maybe some type of time code issue or setting I have incorrectly that is causing this. Any suggestions or advice someone can help me with would be a lifesaver. I have about 50 tapes I need to capture. Thank you in advance!
        • 1. Re: Audio Sync Issue on MiniDV Tape Capture
          Meg The Dog Adobe Community Professional
          Do you see this out of sync condition when capturing?
          When you review a captured clip, is the out of sync condition still there in the captured file?
          MtD
          • 2. Re: Audio Sync Issue on MiniDV Tape Capture
            Actually, yes that is usually how I first notice it. If I watch/listen on the camcorder, it's perfectly in sync but if I turn the volume up on the iMac I notice that the audio and video has drifted during capture. The longer it captures, the worse it gets. No dropped frames, and no errors or issues with the video files. As I said before, I CAN capture successfully with that Vidi app so I don't think it's a firewire or connection issue either.
            • 3. Re: Audio Sync Issue on MiniDV Tape Capture
              I would capture the entire tape in Premiere with scene detection on.
              Then delete the clips you dont want from the hdd.
              Driftng might be due to blank/dropped video frames.
              • 4. Re: Audio Sync Issue on MiniDV Tape Capture
                I should clarify, the capture starts out in sync and slowly drifts out of sync as time goes on. So when I begin to capture, everything looks normal on screen and then after awhile I will notice that they are no longer in sync together. This is both as I'm watching live and also in the captured file. The captured file is out of sync regardless of whether it's in a premiere timeline or played back in various apps.
                • 5. Re: Audio Sync Issue on MiniDV Tape Capture
                  Yes, but I just want to verify that if you play back one of the clips that you saw going out of sync during the capture process, the file that is created and the played in Premiere shows that same out of sync condition.
                  MtD
                  • 6. Re: Audio Sync Issue on MiniDV Tape Capture
                    Hmm, interesting idea. I have not tried scene detection yet. Does it split up clips based on time code changes? I prefer to decide when I start and stop the capture on my clips and have never trusted scene detection before. Is there any particular reason it would fix the syncing issue that a manual capture would not?
                    • 7. Re: Audio Sync Issue on MiniDV Tape Capture
                      Are there any camera start/stops within the area you are capturing? This will throw the audio out of sync during dv capture. The more camera start/stops, the more it will drift out of sync.
                      MtD
                      • 8. Re: Audio Sync Issue on MiniDV Tape Capture
                        I have always done full tape with scene detection on.
                        Found this batch capture rather a strain on the camera/tape.
                        start - capture - stop - FF - stop - etc.
                        And also these tapes might have been laying on the shelf for some time.
                        Did you wind and rewind the tape before capture?
                        Might want to give it a go.
                        • 9. Re: Audio Sync Issue on MiniDV Tape Capture
                          Occasionally there are a some scenes that yes, at the time of recording had camera start/stops. I guess I'm confused as I used to capture entire tapes in one long take in Premiere using this exact same method with no problems or sync issues whatsoever. Has something changed in the new versions of CC, or is there a setting that is different now? I don't really care about timecode or anything for these particular tapes as I'm doing a log and capture myself anyway, so I'd much prefer a way of just capturing the raw stream as it's played back. I really thought Premiere would be able to capture a raw file as it's being played, without any type of splitting or syncing issues.
                          • 10. Re: Audio Sync Issue on MiniDV Tape Capture
                            SAFEHARBOR11 Most Valuable Participant
                            24p recordings on the DVX100 camera are actually recorded as interlaced 60i video (29.97 frames / 59.94 fields) using pull-down. Have you tried playing/editing the clips in a regular DV project as 29.97 interlaced rather than a 24p project?
                            24p: the AG-DVX100 and digital filmmaking
                            As for capturing, I did for many years always use Scene Detect (on PC with Premier). Still took 60 minutes to capture a 60 minute tape - does it in one smooth pass, no stopping/starting, but on-the-fly each scene on the tape is treated as a separate clip on the hard drive. If you have gaps in the recording - blue screen, no timecode - well, that is going to mess with ANY kind of capture. I never used 24p, was always regular 60i.
                            Jeff
                            • 11. Re: Audio Sync Issue on MiniDV Tape Capture
                              I've been working with DSLR and raw footage recorded onto cards these days, the only reason I am re-visiting these tapes is because a friend passed away and I have taken the liberty of putting together a small documentary for the family. So it has been a very long time since I've had to do anything with tapes and I realize a lot of changed in Premiere as well as Macs, Operating Systems, etc.
                              What is most frustrating to me is that this used to work perfectly this way and I guess I just don't understand what has changed or what I'm doing wrong at the moment. I really like organization and capturing specific sections or clips to log myself, but it seems that trying a whole tape capture with scene detection seems to be the only solution to try at the moment. The only downside to that is if there were camera start/stops but it all took place within the same scene or if you wanted it all in one clip and it splits it up, but I suppose if that's the only way it will work at this point- it's worth giving a shot. I will try this method and report back if it at least fixes any synching issues. Thanks for the suggestions everyone, I really appreciate it.
                              • 12. Re: Audio Sync Issue on MiniDV Tape Capture
                                Try making a test capture using QuickTime X and see if the sync holds there.
                                MtD
                                • 13. Re: Audio Sync Issue on MiniDV Tape Capture
                                  Unfortunately, doing tape capture with scene detection resulted in the same out of sync issue. Any other suggestions and I'm all ears but there is obviously something very weird happening here.
                                  • 14. Re: Audio Sync Issue on MiniDV Tape Capture
                                    Did you try QuickTime 10?
                                    MtD
                                    • 15. Re: Audio Sync Issue on MiniDV Tape Capture
                                      I am not a mac person but it could be a CC issue.
                                      Download Premiere CS6 and try again to capture.
                                      • 16. Re: Audio Sync Issue on MiniDV Tape Capture
                                        Kevin-Monahan Adobe Employee
                                        jordanwalkert,
                                        Still experiencing this issue? If not, how did you fix it?
                                        Let us know!
                                        Kevin
                                        • 17. Re: Audio Sync Issue on MiniDV Tape Capture
                                          Never found a solution unfortunately. Tried Adobe Premiere CC, 2017, and CS6. All had the same issues. Also tried Quicktime X but it defaults to using Apple Pro Res with crazy files and does not let you customize or adjust the quality in any way so I did not mess with that a lot as I don't think that's the best way to capture the purest signal of video. I will say, the synching is significantly worse and occurs more when there are large cuts or drop outs in the video. Which leads me to believe it's probably some type of timecode issue or something. I used to capture entire tapes in the past that had terrible cut outs, glitches from dirty heads, etc. and although I had bad digital artifacting- I still never lost synch of audio and video. I'm guessing it's either something with Mac's newer OS, Mac's newer hardware (than the previous Macs I used to have), a lack of on board firewire and having to use a Thunderbolt adaptor, or something Adobe has changed in their software. Very frustrating for what I'm trying to do : (
