Expand my Community achievements bar.
How to include an HTL list inside an HTL list
Avatar
Level 4
Hi All,
I have the following Java code in my Java component bean :-
public List<String> getOuterList()
    final List<String> outerList = new ArrayList<String>();
    outerList.add("Outer1");
    outerList.add("Outer2");
    outerList.add("Outer3");
    return outerList;
public List<String> getInnerList()
    final List<String> innerList = new ArrayList<String>();
    innerList.add("Inner1");
    innerList.add("Inner2");
    innerList.add("Inner3");
    return innerList;
The HTL below (examples 2 and 3) is not producing the expected result :-
<p>-------------------------EXAMPLE 1  (WORKS)-------------------------</p>
<ul data-sly-list.outerListItem="${sideNavBean.outerList}">
    <li>${outerListItem}</li>
</ul>
<ul data-sly-list.innerListItem="${sideNavBean.innerList}">
    <li>${innerListItem}</li>
</ul>
<p>-------------------------EXAMPLE 2  (FAILS TO RENDER INNER LOOP)-------------------------</p>
        </ul>
    </li>
</ul>
<p>-------------------------EXAMPLE 3  (FAILS TO RENDER INNER LOOP)-------------------------</p>
<template data-sly-template.INNER>
    <p>Template for inner</p>
    </ul>
</template>
        <div data-sly-call="${INNER}"></div>
    </li>
</ul>
Result produced by HTL and Java above :-
Outer1
Outer2
Outer3
Inner1
Inner2
Inner3
Outer1
Outer2
Outer3
Outer1
Template for inner
Template for inner
Outer2
Template for inner
Template for inner
Outer3
Template for inner
Template for inner
Why are examples 2 and 3 not showing the inner loop?
How can I include an inner loop inside an outside loop?
Thanks.
Avatar
Level 4
I have also tried the HTL code below which produces the same result.
Example 1 works.
Examples 2 and 3 only render outer loop and don't render inner loop.
Thanks.
<ul  data-sly-use.sideNavBean3="${'io.package.SideNav'}"  data-sly-list.outerListItem="${sideNavBean3.outerList}">
    <li>3:${outerListItem}</li>
</ul>
<ul  data-sly-use.sideNavBean4="${'io.package.SideNav'}"  data-sly-list.innerListItem="${sideNavBean4.innerList}">
    <li>4:${innerListItem}</li>
</ul>
        </ul>
    </li>
</ul>
    </ul>
</template>
    </li>
</ul>
Avatar
Community Advisor
I tried your code with some modification , all examples are working fine.
HTL
<h2>This is a New List </h2>
<sly data-sly-use.sideNavBean="com.aem.community.core.components.OutInList">
</ul>
</ul>
        </ul>
    </li>
</ul>
<template data-sly-template.INNER="${ @ sBean}">
    <ul data-sly-list.innerListItem="${sBean.innerList}">
    </ul>
</template>
        <div data-sly-call="${INNER @ sBean = sideNavBean}"></div>
    </li>
</ul>
JAVA
package com.aem.community.core.components;
import java.util.ArrayList;
import java.util.List;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.adobe.cq.sightly.WCMUsePojo;
public class OutInList extends WCMUsePojo{
  private final Logger logger = LoggerFactory.getLogger(getClass());
  @Override
  public void activate() throws Exception {
  // TODO Auto-generated method stub
      return outerList;
      return innerList;
Arun
Arun Patidar
Avatar
Level 4
Thanks Arun.....
Very strange.....
Does not work on my AEM 6.3 server.    Only displays outer list and does not display inner list.....
Avatar
Community Advisor
I tried in 6.3 , works for me.
Can you try my code and check?
Arun Patidar
