8 Replies Latest reply on Jul 19, 2018 12:34 AM by Laubender
    Selection export without groupping
    davidc19923048 Level 1
      Hello friends,
      I need to export an IDMS from a seleciton.
      I found a solution here https://forums.adobe.com/message/10343871#10343871 , But it groups the selection to export.
      Somehow, Adobe Indesign exports without groupping, in File->Export...
      Someone knows how to do this?
      Tks
        • 1. Re: Selection export without groupping
          Hi David,
          what is your version of InDesign?
          If you are on InDesign CC 2018.1 try the new methods exportPageItemsSelectionToSnippet() or exportPageItemsToSnippet(). See DOM documentation here:
          https://www.indesignjs.de/extendscriptAPI/indesign-latest/#Document.html#d1e49256__d1e5371 3
          Regards,
          Uwe
          • 2. Re: Selection export without groupping
            Thanks Laubender, I was using exportFile.
            I didn't know this functions.
            Regards
            • 3. Re: Selection export without groupping
              davidc19923048  wrote
              … I didn't know this functions.
              It's rather new. Introduced with InDesign CC 2018.
              Regards,
              Uwe
              • 4. Re: Selection export without groupping
                Hi David,
                method document.exportPageItemsToSnippet() is very interesting, I think.
                Two arguments:
                File and Array of pageItem id numbers.
                That means, and I tested this, you can export various page items from various spreads of a document to one single IDMS file!
                And you can be very picky. ;-)
                Means you can export e.g. two out of three page items from a group item without exporting the whole group.
                But be forewarned, in this case the preview image on the place cursor will show the whole group of items, not only the two ones you picked.
                Regards,
                Uwe
                • 5. Re: Selection export without groupping
                  Hi Laubender
                  It's a realy powerfull function. I made some implementations, it works realy good.
                  Thanks for the help.
                  • 6. Re: Selection export without groupping
                    Hi David,
                    after testing a bit more with exportPageItemsToSnippet() I suggest that you are looking after the length of app.selection.
                    My point:
                    The preview image of the IDMS exported with exportPageItemsToSnippet() is always done from the selection if something is selected. Regardless if the items specified that should be exported are part of the selection or not.
                    That explains my experience very well where the whole group was visible in preview of the IDMS as I exported only two out of three items in the group. I had that group selected when running the script! I tested again without selecting anything and finally only the two items were shown in the preview of the exported IDMS.
                    So app.select(null) would be the thing to do before running the method.
                    Another important thing:
                    If the items you want to export are part of a
                    1. MSO ( MultiStateObject )
                    2. Button
                    3. Graphic Frame ( a pasted inside group's page item is the item I want to export*  )
                    the whole MSO, the whole button or the whole graphic frame is exported to IDMS.
                    Not only the items in the array of the second argument.
                    ( There may be other nested structures as well where this will happen, but not with items that belong to a group or anchored frames. )
                    In that case a workaround could be to work with duplicates of the target items.
                    Regards,
                    Uwe
                    * EDIT
                    • 7. Re: Selection export without groupping
                      Thanks Laubender
                      Your explanation was very helpfull.
                      I'll follow you suggestions
                      Thanks friend
                      Regards
                      • 8. Re: Selection export without groupping
                        2. Button
                        I can see the issues listed above also with exportPageItemsSelectionToSnippet() .
                        Not only with exportPageItemsToSnippet().
                        Regards,
                        Uwe
