• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Cut selected image out of picture, can't use selection as path
Community Beginner ,
Jul 13, 2018 Jul 13, 2018
Does anyone have an idea how I can simply cut this selection of the image out of its background, and use it as a new image?
I have carefully drawn a path around it but can never cut this out of the image. Pathfinder doesn't make a good selection, so I had to draw a the selection, but it seems not to be recognized as a path. I'm losing so much time on this... Thanks in advance! JoSchermafbeelding 2018-07-13 om 11.32.48.png
Views
488
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Jul 13, 2018 Jul 13, 2018
Hi jokev14504565 ,
first refine your path you are drawing, then open your Layers Panel.
There should be two objects:
The frame holding the image.
A polygon that is the path you are drawing.
Select the frame holding your image.
Do Cut.
Select the polygon.
Do Paste Inside.
Regards,
Uwe
Votes
Translate
Translate
Community Expert ,
Personally, I would load the file in Photoshop, masking out the background and save as PSD or TIFF file.
ABAMBO | Hard- and Software Engineer | Photographer
Votes
Translate
Translate
Report
Report
Thanks, but is this the only way? I don't have Photoshop you see... Seems a bit silly to have to buy it for the occasion 🙂
Votes
Translate
Translate
Report
Report
Community Expert ,
You can do as Laubender​ suggests, if you do not have Photoshop (or any other modern image editor) at your hands. It's just more complicated to handle with complex shapes. You create a irregularly shaped image frame.
And yes, if you have only Indesign at your disposal, Laubender's solution is the best you have.
Votes
Translate
Translate
Report
Report
LATEST
That's right, so considering Photoshop in the future is not a bad idea. Thanks for the help!
Votes
Translate
Translate
Report
Report
Community Expert ,
Hi jokev14504565 ,
Do Cut.
Select the polygon.
Do Paste Inside.
Regards,
Uwe
Votes
Translate
Translate
Report
Report
Thanks, this worked! 🙂
Votes
Translate
Translate
Report
Report
