1 Reply Latest reply on Mar 28, 2008 1:04 PM by sternicus
    Trouble exporting swc from Flash for Flex
    sternicus
      I'd like to have my fla live in my src directory in order to reuse
      some classes I created for my Flex app. After publishing, I move the
      swc into the lib directory.
      When publishing the fla inside the main project directory (and moving
      the swc into lib), the component appears just fine when running my
      Flex app. However, when publishing the fla inside the src directory
      (and moving the swc into lib), the component is not visible when
      running my Flex app. Either way, the published swf file works fine.
      The movieclip I'm exporting does not use the auto-generated class, the
      class is specified in a .as file.
      I created a very simple component (no .as file) that does NOT suffer
      from this problem.
      Any idea why I have to publish this file from the main Flex app
      project directory?
        • 1. Re:  Trouble exporting swc from Flash for Flex
          sternicus Level 1
          I figured out that I could reuse my code (inside the src directory) and keep the fla file in the main Flex app directory by adding a classpath in the ActionScript 3.0 Settings in Flash's Publish Settings.
          Publishing the swc from the main Flex app directory now works (when I put the swc in the lib directory).
          I'm still not sure why I'm unable to publish from the src directory and just move the swc into lib.
          Any ideas?
