I'm trying to create a resource that uses an excel spreadsheet to link to various locations in various pdf files. The pdf files are all stored locally on a network in the same folder as the pdfs. I've created destinations in Acrobat, but when I create the hyperlink in excel, it changes the '#' to something else. I'll try and attached screenshots so you can see what I mean. In short, the pdfs open, but just at page 1.
What am I doing wrong?
Use a link like this:
Thanks, but it's still just opening it at the front page. The exact link I'm using is this "June20171F.pdf#nameddest=1" with the file June20171F.pdf being located in the same folder as the spreadsheet.
I bet it's something simple, but it's really annoying me!
Dom
This type of open parameter only works when the file is viewed from the web. It won't work from a spreadsheet that's pointing to a local file.
I knew that I couldn't link to specific page numbers, but I thought destinations would work.
What are the alternatives for using locally stored files? The problem is, is that this project is based on GCSE maths papers and they are not released on public websites until 9 months after the exams have been sat.
Dom
You can create links with named destinations in Adobe Acrobat.
Unless you use a macro I don't think you can do it.
