13 Replies Latest reply on Apr 25, 2008 8:36 PM by jmmorgan
    CFFILE question
    natg504
      I'm trying to read a .cfm file on my server with cffile. This is working okay, except that there is some coldfusion code in that file, and when I write it out, it does not work. It just writes out as text in the source code & nothing is executed. Is there a way to make it write the text as actual code, and not just text?
      Example:
        • 1. Re: CFFILE question
          Level 7
          > just text?
          Umm, maybe with some effort!
          But why are you not using the <cfinclude ...> tag which was built just
          for this type of purpose? Rather then the <cffile...> tag, which was not?
          • 2. Re: CFFILE question
            natg504 Level 1
            Well, I would use cfinclude, but I only want to get part of the page, not the entire thing. I was using the following code to get just the part of the page between the mainContent div tags.
            • 3. Re: CFFILE question
              Dan Bracuk Level 5
              Since you know how to use cffile,
              read the file.
              find the part you want and write that to a new file
              cfinclude the new file
              delete the new file.
              • 4. Re: CFFILE question
                Level 7
                > <!--- get only the part of the page between the mainContent section --->
                > <cfset start = Find('<div id="mainContent">', curPage)>
                > <cfset stop = Find('mainContent -->', curPage)>
                > <cfset curPage = Mid(curPage, start, stop)>
                If this is what you have to work with. You are going to want to look at
                the evaluate() function which says run this string as a chunk of code.
                But it could be a bit tricky.
                If I could do so, I would explore the option of isolating that section
                of code in some manner that can be used in both places it needs to be
                used. That would be the simplest and most scalable solution.
                • 5. Re: CFFILE question
                  Level 7
                  Dan has put forward a suggestion that will work for this.
                  However - if this is what you need to be doing - I would be questioning the
                  entire process, not simply the last step of it.
                  From where I'm sitting, and with the info you've provided, what you are
                  trying to do is *really* *grim*, and _I think_ you should be trying to
                  reconsider your approach here.
                  Adam
                  • 6. Re: CFFILE question
                    natg504 Level 1
                    Adam,
                    If you have any suggestions on another approach to take, that would be helpful. The problem is that I need to display content from the other .cfm pages, and that content is not in a database, so I'm trying to figure out a way to get it & display it. I don't have the ability to change the database, so I can't add the content to the database & just do a query. Also, I can't grab the entire page with a cfinclude because they're created with templates & I would have errors because of things being defined twice. The database does include a field with a link to the .cfm page, but that is all I have to use. I want to grab a section of all those .cfm pages and display them all on the same page.
                    • 7. Re: CFFILE question
                      Level 7
                      natg504 wrote:
                      > Adam,
                      > page.
                      Can you redesign the original page? Pull out this common section into
                      it's own file that is then <cfinclude... it into both places?
                      • 8. Re: CFFILE question
                        Level 7
                        Why do you need to do this? I'm not being obtuse (well: not *meaning* to
                        be obtuse ;-), just trying to work out where you're coming from, so I can
                        suggest how you might try to effect a solution.
                        Adam
                        • 9. CFFILE question
                          natg504 Level 1
                          The site uses a content management system, so I'm limited on the changes I can make to any pages. People enter the text & html for an article into a form & create a .cfm page from that using the cms. What I'm trying to do is dynamically get all of the articles from a single month & put them on to one page. I'm using the cfdocument tag to make that page a pdf, so that monthly issues of this publication will be automatically generated for users to download.
                          I can figure out what articles to get because there is a database with a date & url for each article. The rest of the article content is not in a database though.
                          • 10. Re: CFFILE question
                            Level 7
                            Right, I see.
                            Well all you can really do then, I guess, is proceed the way you started.
                            Sorry to sidetrack you a bit, but sometimes people do some really weird
                            things when the actual solution is easier, so sometime sit's better to coax
                            a bit more info out of them to see what's going on.
                            So, anyhow, you've used find() to extract the boundaries of the patch of
                            content that you need; use mid() to pull it out, write it to a temporary
                            file and then <cfinclude> that file. Delete the temp file afterwards.
                            One thing to bear in mind here - and where you were going wrong -
                            *outputting* the CF code is not the same as executing it. You need to
                            remember that it's not the CFML source code that's executed; it's compiled
                            into byte code first by the CF server, then the byte code is executed. So
                            you need to pass the source code to the CF server, not to the web browser.
                            Which is why you need to <cfinclude> it (or <cfmodule>, or any other way
                            one can call a file to execute it. Just not simply outputting it.
                            Adam
                            • 11. Re: CFFILE question
                              jmmorgan
                              I would think that you should be getting the articles from the CMS in a different manner than scraping the page but I will asume you have your reasons. So how about this:
                              <cfsavecontent var="curPage">
                              <cfinclude template="xyz.cfm" >
                              </cfsavecontent >
                              It would save two file read/writes.
                              • 12. Re: CFFILE question
                                Dan Bracuk Level 5
                                </cfsavecontent >
                                Interesting approach. Where is the part where the code executes?
                                • 13. Re: CFFILE question
                                  jmmorgan Level 1
                                  Hi Dan -
                                  CF processes and executes all CFML found in files included through a cfinclude tag.
                                  - Jason
