1 Reply Latest reply on Jan 7, 2009 6:49 AM by matthew horn
    varied column widths in ColumnChart
    mjovel
      Is it possible to have varied column widths based dynamically loaded values on a ColumnChart in Flex? I looking to load data from an xml file where one value represents the height of the column bar while the other value is represented by the width of the column bar?
        • 1. Re: varied column widths in ColumnChart
          matthew horn Level 3
          mjovel, I talked to one of the flex engineers and he said there is no exposed property to do such a thing. However, you can override the updateDisplayList() method of ColumnSeries and do something there. If you see the code there, there is lo (leftOffset) and ro (rightOffset) calculated and these are same for all the columns, the lo and ro needs to be changed to suit your requirements.
          Hopefully, this is enough to get you going,
          matt horn
          flex docs
