• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Mercury Transmit freezes
Engaged ,
Jul 17, 2018 Jul 17, 2018
Since the AE 15.1 update my output via mercury transmit freezes periodically and the only way to unfreeze it is to switch to another comp or footage window and then switch back again. At first I thought it was my Blackmagic card but the same issue also occurs when outputting via MT to a second monitor attached to my nVidia. Updating this morning to 15.1.2 hasnt fixed anything.
AE 15.1 - 15.1.2
Win 10
i9-7900X
128GB ram
2xnVidia 1080Ti
Views
2.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Engaged ,
Jul 23, 2018 Jul 23, 2018
Seems this is related to nVidia drivers even when MT is outputting via my blackmagic. Uninstalling nVidia drivers and letting Windows install it's own version of drivers seems to fix it. Not a permanent fix for me though as I need proper nVidia drivers to make other stuff work ie Octane.
Votes
Translate
Translate
Report
Report
Engaged ,
Aug 03, 2018 Aug 03, 2018
Lumetri scopes also freeze at the same time....
Votes
Translate
Translate
Report
Report
LEGEND ,
Sounds like you're in the fun realm of GPU driver bingo! It's a frustrating place to be and I sympathize with you.
Other than trying some different versions of the NVIDIA drivers, I don't have any other suggestions.
If you have time, you might try getting in contact with Adobe support. They can sometimes help with the really technical stuff like this, but patience on your part is going to be required because they'll probably go through many of the steps you've already tried.
Votes
Translate
Translate
Report
Report
Engaged ,
Yes, three times They confirmed it was nVidia driver related and trying to find a fix.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Aug 23, 2018 Aug 23, 2018
We are running into the same problem actually. On the newest update for AE and on the newest Nvidia drivers (398.82) for our dual GTX 1080ti's. We do not have a BMD card in this machine, only outputting via the GPU. This was occurring on the graphics driver that we had previously (from May of this year) and then again after we updated to the newest version yesterday. Hoping to find a better answer than randomly throwing drivers at it over and over until it works consistently.
Votes
Translate
Translate
Report
Report
Engaged ,
Yes, gfx card driver roulette isn't exactly a proper solution.
I wonder if it's a coincidence that we are both using dual 1080Ti? This has just made me remember an issue I had a few versions ago with Premiere. I was suffering from really poor performance until I want into the nVidia Control Panel > manage 3D settings and then set Premiere to use only 1 GPU. Premiere is only capable (or was at the time) of only using 1 GPU so the fact that both were enabled was freaking it out. I've just done the same for AE and will report back later on today.
Votes
Translate
Translate
Report
Report
If it matters, we are not using ours in SLI configuration at all. Just two 1080ti's for GPU 3D rendering primarily. Not necessarily anything, but I figure more information in weird troubleshooting like this is always better.
Votes
Translate
Translate
Report
Report
Engaged ,
Me neither, I've never used SLI. It's only useful for games and generally messes with everything else. If you look inside the nVidia control panel though you will see that by default all your software will be set to use both GPUs (global).
Votes
Translate
Translate
Report
Report
Engaged ,
Aug 24, 2018 Aug 24, 2018
I can confirm that changing nVidia settings to only use only 1 GPU does not help matters.
Votes
Translate
Translate
Report
Report
New Here ,
Mar 14, 2019 Mar 14, 2019
Also having the same problem on 3 different machines using various GPU's all nVidia. Using black magic card doesn't help. Very frustrating bug, I don't have this problem in premiere so pretty sure its an After effects bug. Have tried going through Adobe support but was a complete waste of time with just the usual obvious steps and no follow up when that didn't work....
Have you had any luck resolving this since your original post?
Votes
Translate
Translate
Report
Report
Engaged ,
Apr 18, 2019 Apr 18, 2019
Still no fix for this in latest AE version. Hey, but at least we have content aware fill now!!
Adobe, please get your priorities right.
Votes
Translate
Translate
Report
Report
Engaged ,
Jul 03, 2019 Jul 03, 2019
Another version (16.1.2) of AE comes around and still no fix. This happens on different machines and on both Mac & Windows. PLEASE CAN WE GET A FIX ALREADY?
Votes
Translate
Translate
Report
Report
Engaged ,
Jul 28, 2020 Jul 28, 2020
Two years on and this is still an issue.
Votes
Translate
Translate
Report
Report
Engaged ,
Dec 15, 2020 Dec 15, 2020
Just got myself a new machine. New GPUs, upgraded blackmagic card. Same problem. This is clearly a software bug that effects all systems. Why is there no fix yet?
Votes
Translate
Translate
Report
Report
Nov 23, 2023 Nov 23, 2023
Still no clear fix for this. I find it unbelievavle that bugs like this have sat in Premier Pro for years without being addressed.
Votes
Translate
Translate
Report
Report
Engaged ,
LATEST
Yes, 5 years on and the problem still exists. At this point it's embarrassing.
Votes
Translate
Translate
Report
Report
