31 Replies Latest reply on Sep 19, 2018 3:22 PM by bryanp73998590
    Premiere Pro Workspaces STILL not working
    Impalaboy Level 1
      This morning I updated to Version 12.1.2 (Build 69) hoping that the problem with my Workspaces would be fixed but it wasn't.
      When I arrange my windows the way I like them, I go Workspaces --> Save As New Workspace, title and save it. But when I close Premiere and re-open a project, the windows are not where I saved them. If I go to Workspaces --> and select the new one I just saved, nothing changes!
      This was a problem before today's update and continues to be a problem despite this from Adobe's list of Bug Fixes in the new version: "Workspaces save now correctly with the project"
      I have been putting up with this issue hoping it would be fixed in the next update but sadly it was not.
      Any suggestions?
      macOS
      High Sierra - Version 10.13.5
      2.7 GHz 12-Core Intel Xeon E5
      64 GB 1866 MHz DDR3
      AMD FirePro D700 6144 MB
        • 1. Re: Premiere Pro Workspaces STILL not working
          R Neil Haugen Adobe Community Professional & MVP
          Did you dump your media cache/cache database and preferences files with the new update?
          Neil
          • 2. Re: Premiere Pro Workspaces STILL not working
            Kevin-Monahan Adobe Employee
            Impala Boy,
            Did you try this with a new project or an existing project? If you have not already done so, try this with a new project.
            Kevin
            • 3. Re: Premiere Pro Workspaces STILL not working
              Impalaboy Level 1
              Just tried that. No change.
              • 4. Re: Premiere Pro Workspaces STILL not working
                Impalaboy Level 1
                Just created a new project and new workspace. Saved workspace with new name, closed Premiere, re-launched and windows were not were I left them.
                Chose the new workspace that I had just created and no change to the windows.
                • 5. Re: Premiere Pro Workspaces STILL not working
                  OK, let me tell engineering about it. See what they say.
                  Kevin
                  • 7. Re: Premiere Pro Workspaces STILL not working
                    Meg The Dog Adobe Community Professional
                    Yes. The update does not fix the workspace issue for me, either - old project, new project - it doesn't matter.
                    I reset them, save them, save the project and . . . the workspaces keep defaulting on project launch to some unsaved configuration.
                    MtD
                    • 9. Re: Premiere Pro Workspaces STILL not working
                      Impalaboy Level 1
                      I filed a bug fix request. Now I want my Preferences back.
                      • 10. Re: Premiere Pro Workspaces STILL not working
                        Wes Howell Adobe Employee
                        Just to clarify - the issue is that when Premiere opens it is not defaulting the last workspace that was selected, correct?
                        The new workspace you created exists and you can switch to it manually after reopening the project and it works properly?
                        Hoping to confirm that this is an issue of what workspace is being used by default when reopening projects.
                        Thanks!
                        • 11. Re: Premiere Pro Workspaces STILL not working
                          Yes. In my case I can create a new workspace and it will save it - but the order and selection of workspaces to be displayed in the Workspace bar is not/never retained.
                          If I reset that order and choices for the Workspace bar, once I save and close the program, the next time I open it opens with different workspaces listed in the workspace bar.
                          EDIT: This problem began with the last update and continues in the current release.
                          MtD
                          • 12. Re: Premiere Pro Workspaces STILL not working
                            Impalaboy Level 1
                            When I open Premiere, the windows are in a position that I did not put them in. If I try to load my Workspace that has the correct window positions, nothing happens.
                            It indicates that my workspace is loaded, but the windows are not in the proper place.
                            • 13. Re: Premiere Pro Workspaces STILL not working
                              Hi Meg,
                              Have you reset prefs (This has resolved the same issue for some) Also, have you tried renaming your workspaces folder in order to have Pr create a new one?      I'd be happy to work with you directly to try a few things if you would like.
                              Wes
                              • 14. Re: Premiere Pro Workspaces STILL not working
                                Hi Impalaboy,
                                Are you on Mac or Windows?   Is this occurring on only one machine?  Happy to work with you on this to track the issue down.
                                Wes
                                • 15. Re: Premiere Pro Workspaces STILL not working
                                  Yes, I have reset preferences and deleted the workspaces folder to have Premiere Pro reconstruct a new one when the problem first appeared in the last version with no result.
                                  I again deleted preference after installing the current version and no result.
                                  Do you want me to try those again? Can you refresh my memory as to where the Workspace Folder is on Mac OS?
                                  MtD
                                  • 16. Re: Premiere Pro Workspaces STILL not working
                                    Impalaboy Level 1
                                    As stated in my original post, I am on a Mac.
                                    It's happening on more than one machine apparently, according to Meg the Dog.
                                    In all this troubleshooting and re-setting up my preferences, I discovered a workaround that will get me by for now.
                                    Gotta run...gotta lot of work to do.
                                    • 17. Re: Premiere Pro Workspaces STILL not working
                                      I had to remove the Workspaces folder a couple times in the last build, as I initially had this problem. After a couple CC Cleaner Tools utilization to blast both the app & assorted files off the computer, and repeated manual dumping of the Worspaces folder, I got it working.
                                      So ... yea, I'd recomment dumping that folder, rebooting, then trying again.
                                      Neil
                                      • 18. Re: Premiere Pro Workspaces STILL not working
                                        I have repeatedly deleted the folders Archived Layouts and Layouts that live on the path:
                                        Users/me/Documents/Adobe/Premiere Pro/12.0/Profile-CreativeCloud-
                                        cleared preferences by holding down the option key at program launch,
                                        created a new empty project, reset the workspaces order and created and saved new workspaces, and then saved and closed the Project.
                                        On next launch the workspaces are reset to default.
                                        So on launch I get this:
                                        when what I saved was this:
                                        MtD
                                        • 19. Re: Premiere Pro Workspaces STILL not working
                                          Hi Meg,
                                          Thanks for investigating.
                                          It seems what may have helped others with this problem was deleting or renaming the (non creative cloud) Profile folder as Premiere will automatically build a new one.   I'm wondering if a conflict has been introduced from syncing your settings from the cloud.   Also wondering if you might have an older version of Premiere installed as well?
                                          For Premiere 12,  I'm guessing you may have 2 different profile folders in your documents folder.   While this is as designed and normal, it may be an important thing to investigate a bit more (or rebuild both) in order to figure out the bug occurring here.
                                          Can you (backup as needed) then rename both of your old profile folders and check the regular behavior before syncing from the cloud?    Also remember that Pr can scan previous versions for workspaces to make them available in newer releases as well.
                                          Please lmk if this helps!
                                          • 20. Re: Premiere Pro Workspaces STILL not working
                                            OK, uninstalled all previous versions using Adobe uninstallers, changed the two Profile versions names to force rebuild, and I do not believe I sync with the cloud unless I force the sync.
                                            Still get the same behavior regarding workspaces.
                                            Mac OS 10.13.6
                                            PPRo 12.1.2
                                            MtD
                                            • 21. Re: Premiere Pro Workspaces STILL not working
                                              Hi Meg,
                                              Is there still a folder for your previous version of Pr in your documents folder or was it removed during uninstall?  Worth checking just to be thorough.
                                              Re: the workspace bar config and workspace order - I believe that setting should be saved as part of your prefs file (in your profile folder). I just edited the configuration of my workspace bar and it modified my Adobe Premiere Pro Prefs file.   This is something worth checking / verifying.   When you create new workspaces, do they show up on the far right of the workspaces bar?   With your most recent investigation Is it just not saving them after you change their order?
                                              Could you try editing the order of the workspaces bar and see if that is causing a change to the timestamp of the Adobe Premiere Pro prefs file?   Deleting or resetting the prefs file right before testing this might be a good idea as well.
                                              Thanks for your patience and assistance.    Something strange is going on here but all this info is helpful.
                                              Wes
                                              • 22. Re: Premiere Pro Workspaces STILL not working
                                                The only version in Users/me/Documents/Adobe/Premiere Pro is the folder for version 12.0.
                                                If I create new workspaces, and change the order and what workspaces appear in the workspace bar, the Layouts xml. the file at Profile-me/Adobe Premiere Pro Prefs, and the Archived Layouts xmls all show date modified is changed to the current time.
                                                If I then save the Project, close it and reopen it, the workspace bar still resets to default, and does not reflect my changes.
                                                MtD
                                                • 23. Re: Premiere Pro Workspaces STILL not working
                                                  Can you try a reinstall of 12?
                                                  Are you a small shop/single user or an enterprise account?  (Prefs can vary for some enterprise accounts)
                                                  Wes
                                                  • 24. Re: Premiere Pro Workspaces STILL not working
                                                    Thanks for your help -
                                                    Single user.
                                                    Using the Creative Cloud app, I uninstalled the last and only version of Premiere Pro I have on this computer, choosing to delete preferences as well.
                                                    I downloaded the current version.
                                                    Problem remains . . .
                                                    As a test, rather than move the workspaces to the Do Not Show area of the Edit Workspaces Pane, I actually select and Delete the ones I don't want to see - and still, the next time I launch the app, the default workspaces are shown.
                                                    While this is not a dealbreaker, it is pebble in my shoe.
                                                    Problem originated in the last version and continues to present.
                                                    MtD
                                                    • 25. Re: Premiere Pro Workspaces STILL not working
                                                      I understand... the pebble is annoying me as well.
                                                      I will do a little digging and see if I can find someone with more workspaces expertise.
                                                      Will be in touch,
                                                      Wes
                                                      • 26. Re: Premiere Pro Workspaces STILL not working
                                                        Hi Mtd,
                                                        After doing some more digging, I believe the core issue here may have arisen from having both local and cloud workspace settings.   It's an unwieldy bug but I have something simple and easy for you to try.
                                                        Can you add your workspaces, edit the workspace bar, then upload your profile to the Cloud?
                                                        Let's see if that resets things and gets you back up and running.
                                                        Wes
                                                        2 people found this helpful
                                                        • 27. Re: Premiere Pro Workspaces STILL not working
                                                          Well, I was certainly hoping that would fix it but, sorry, it didn't.
                                                          I configured the workspaces and workspace bar, synced (uploaded) settings with the cloud, then saved and closed the project.
                                                          I then reopened the project and the default workspaces were back - so I synced (downloaded) from the cloud, and my custom workspaces are there but the workspace bar still displays the default set of workspaces.
                                                          Thanks for the suggestion.
                                                          MtD
                                                          • 28. Re: Premiere Pro Workspaces STILL not working
                                                            MyerPj Level 3
                                                            I'm just throwing this out there in case they are related, but I've noticed for awhile now that PP doesn't even save the screen settings. Size and location in Windows. It always opens full screen rather than where you had it opened last as is typical and as the other CC apps do.
                                                            • 29. Re: Premiere Pro Workspaces STILL not working
                                                              juanmario Level 4
                                                              I tell him my experience in case he serves someone, it happened twice and he solved it in the following way.
                                                              Start the program by holding down the following key combination:
                                                              Alt (Option) + Shift
                                                              The Alt (Option) key when you start the application allows you to reset the configuration.
                                                              The Shift key allows you to reset the add-on cache.
                                                              If you start with the welcome screen is that it went well.
                                                              I open the project by default, TUTORIAL PROJECT get Started.prproj
                                                              With the program open, I'm going to:
                                                              Users /? / Documents / Adobe / Premiere Pro / 12.0 / Profile-?
                                                              and I delete Adobe Premiere Pro Prefs.
                                                              I return to accommodate my work space, because in my case my workspace is saved but it does not respect the order I give it, and I close the program.
                                                              I start the program again, I look for the project I was in, I open it and now it keeps the configuration.
                                                              • 30. Re: Premiere Pro Workspaces STILL not working
        Phil Mariasy Level 1
        Has this issue been pursued any further by Adobe? I have discovered the same problem since updating to 12.1.2 (build 69). I have a triple display-desktop configuration for video; 2 Thunderbolt Apple displays for the PP workspace, and 1 HDMI for program monitor (probably not unusual). My custom workspaces (I use several depending upon many things) are almost always configured into 2 pannel groups, each on a separate display. When I open a saved project, and/or cycle through saved workspaces within a project, the 2 pannel groups will open atop each other on a single display, whereas they were saved as 2 pannel groups, one on each display. Follow?
        As you suggested, it seems that this may be related to conflicting profiles, local and cloud (i.e. user/documents/adobe/premiere pro/12.0/profile (there are 2 folders here: "profile/(user)" and "profile/CreativeCloud.
        Further, within .../CreativeCloud, there seem to be 2 "layouts" folders: "Archived Layouts" and "Layouts". I have observed which .xml file is saved on the finder as I save that corresponding workspace within the PP app, but the .xml's seem to go into the Layouts folder and/or the Archived Layouts folder with no rhyme nor reason.
        Thoughts? (I have private-messaged you if you care to connect with me directly). Thanks Wes!!
        • 31. Re: Premiere Pro Workspaces STILL not working
        bryanp73998590 Level 1
        This solved my issue.
