I am using AEM 6.2 and while creating a page i m setting its advanced Property of redirect to another Page. But this is not happening. the resourceSuperType being used is foundation/components/page. Redirect code in page.jsp is as following:
<%@page session="false"
contentType="text/html; charset=utf-8"
import="com.day.cq.commons.Doctype,
com.day.cq.wcm.api.WCMMode,
com.day.cq.wcm.foundation.ELEvaluator" %><%
%><%@taglib prefix="cq" uri="http://www.day.com/taglibs/cq/1.0" %><%
%><cq:defineObjects/><%
// read the redirect target from the 'page properties' and perform the
// redirect if WCM is disabled.
String location = properties.get("redirectTarget", "");
// resolve variables in path
location = ELEvaluator.evaluate(location, slingRequest, pageContext);
boolean wcmModeIsDisabled = WCMMode.fromRequest(request) == WCMMode.DISABLED;
boolean wcmModeIsPreview = WCMMode.fromRequest(request) == WCMMode.PREVIEW;
if ( (location.length() > 0) && ((wcmModeIsDisabled) || (wcmModeIsPreview)) ) {
// check for recursion
if (currentPage != null && !location.equals(currentPage.getPath()) && location.length() > 0) {
// check for absolute path
final int protocolIndex = location.indexOf(":/");
final int queryIndex = location.indexOf('?');
String redirectPath;
if ( protocolIndex > -1 && (queryIndex == -1 || queryIndex > protocolIndex) ) {
redirectPath = location;
} else {
redirectPath = slingRequest.getResourceResolver().map(request, location) + ".html";
// include wcmmode=disabled to redirected url if original request also had that parameter
if (wcmModeIsDisabled) {
redirectPath += ((redirectPath.indexOf('?') == -1) ? '?' : '&') + "wcmmode=disabled";
response.sendRedirect(redirectPath);
} else {
response.sendError(HttpServletResponse.SC_NOT_FOUND);
return;
// set doctype
if (currentDesign != null) {
currentDesign.getDoctype(currentStyle).toRequest(request);
%><%= Doctype.fromRequest(request).getDeclaration() %>
<html <%= wcmModeIsPreview ? "class=\"preview\"" : ""%>>
<cq:include script="head.jsp"/>
<cq:include script="body.jsp"/>
</html>
i have tried to use foundation/components/redirect, but this is also not working. Can you help me with workaround or a solution for this?
Views
Total Likes
Check below code :
You need to call this in body.html of your page
import java.io.IOException;
import javax.servlet.http.HttpServletResponse;
import org.apache.sling.api.SlingHttpServletResponse;
import org.apache.sling.api.resource.ValueMap;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import com.adobe.cq.sightly.SightlyWCMMode;
import com.adobe.cq.sightly.WCMUsePojo;
import com.day.cq.wcm.api.Page;
public class RedirectHandler extends WCMUsePojo {
private static final Logger LOG = LoggerFactory.getLogger(RedirectHandler.class);
public RedirectHandler() {
super();
LOG.info("Entry into RedirectHandler constructor");
private ValueMap properties;
private SlingHttpServletResponse response;
private SightlyWCMMode wcmMode;
private Page currentPage;
@Override
public void activate() {
properties = getProperties();
wcmMode = getWcmMode();
currentPage = getCurrentPage();
response = getResponse();
public void getConfigureResponse() {
String redirectPath = properties.get("customRedirectTarget", "");
if ((redirectPath != "" )&& ((wcmMode.isDisabled()) || (wcmMode.isPreview()))) {
if (currentPage != null && !redirectPath.equals(currentPage.getPath())) {
response.setStatus(HttpServletResponse.SC_MOVED_PERMANENTLY);
response.setHeader("Location", redirectPath + ".html");
response.setHeader("Connection", "close");
} else {
try {
} catch (IOException e) {
LOG.error("IOException",e);
return;
