Hello, I'm trying to set up something on a shared network to be able to search keywords on one machine that was inputted on another. All the raw footage/images are stored on a SmallTree server. I am able to input keywords into the files through bridge and Im even able to see the keywords. The problem is I have to go to the folder that the files are contained in first and let it cache/load, then i am able to search for those keywords. With various camera folder structures, this would take forever. Is there a way around this? Thanks for any help!
Use the Edit > Find command as below:
Bridge has known issues with search and needing to index folders first. At some point, if you have enough files, you need to look at a better DAM.
Thanks! I was using the search bar in the top right! You my friend are a life saver
