• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Framemaker Not Exporting TOCs to PDF with Nested Book
Community Beginner ,
Jul 19, 2018 Jul 19, 2018
I have a nested book (a book of books) where each sub-book is a chapter.  Each chapter has its own TOC at the beginning.  Everything is fine when looking at each individual chapter *.book file.  However, when I export the top level book to PDF it just omits all of the TOCs.  How do I get the TOCs from each sub-book to show up in the PDF?
Views
327
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Can you provide a screenshot of your .fm book file, and of the results of the PDF?
Votes
Translate
Translate
Report
Report
Yes.  This is a snip of the top-level book tree:
The "Pre-Manual & Safety Section" is not really part of the body of the manual and doesn't have visible page numbers.  "Operator's Manual Section 1" is chapter 1 (manually set in the numbering properties for that object in the book).  Here is the book tree for the section 1 book file:
The TOC for chapter 1 is two pages so the content starts on page three.  However when the top-level book is saved to PDF, it doesn't export the "1200-25 CC Operator's Manual Section 1 TOC.fm" (and all of the other chapter TOCs) with the rest of the book.  Below I have noted in a screenshot of the PDF where the chapter 1 TOC should have been, but wasn't.
The page numbering is changed during the export process so that the first file AFTER the TOC is now page 1.  When I export just the "Section 1" book by itself, it saves the PDF with the TOC just like it should.
Votes
Translate
Translate
Report
Report
Community Expert ,
Operators Manual Nested.book doesn't have a generated TOC
Create a TOC for your highest level book and you should be good to go.
Votes
Translate
Translate
Report
Report
I don't want a TOC for the top level book.  I want one for each chapter.  That's the reason I have a generated TOC in each sub-book.  But, as stated, those TOCs are being excluded from the PDF.
Votes
Translate
Translate
Report
Report
Community Expert ,
Thanks for the clarification. Folks often refer to the bookmarks in a PDF as the TOC, thus the request for more info.
So you have pages within the PDF that are dropped when saving as PDF with your current setup...That looks like you need to file a bug at adobe.com/go/wish.
One alternate way to arrange your book would be to consolidate your chapters into a single file and utilize the mini TOC function instead.
-Matt
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Hello, i have just dropped a persona message to you and if you could share a sample so we could look at the same.
thanks,
Amitoj Singh
Votes
Translate
Translate
Report
Report
Jul 20, 2018 Jul 20, 2018
LATEST
Done.
Votes
Translate
Translate
Report
Report
