Hi
I'm attempting to convert a .3DS file into .C4D using Cinema 4D Lite in After Effects. However my problem occurs right away as I try to open the .3DS file in Cinema 4D Lite - it cannot be opened (error: unknown file format). I am completely new to Cinema 4D Lite, so I'd like to know if it is possible in the first place to open a .3ds file in C4D Lite, or do I need the full version? Alternatively, are there any other ways to open the file in order to convert it to .C4D? I wish to convert the file in order to use it in Video Copilot which does not support .3ds.
I'm using AE 15.1.2 on MacOS (v10.13.4),
3,2 GHz Intel Core i5
RAM 32 GB
Mr. Heaton is incorrect. C4D can import legacy 3DS files just fine. The pertinent question therefore would have to be whther or not the file actually was correctly prepared and exported from MAX and that simply doesn't seem to be the case here. so unless you have access to a fully licensed install of MAX and can check the file and fix those issues it's probably not going to be usable.
Mylenium
Neither After Effects nor Cinema 4D directly support 3D Studio Max project files.
You could give this a try: MaxToC4D – 3DtoAll
Mylenium
Ooops. Well, 50% incorrect. Or 50% right?
After Effects won't import or open a 3DS file, but C4D Lite will.
Start a Comp, add a new MAXON CINEMA 4D File as a layer to launch C4D Lite and then open or merge the 3DS file.
Obviously, I don't open 3DS files that often, so here's the info from the Maxon Cinema 4D online help:
https://help.maxon.net/us/#F3DSIMPORT-F3DSIMPORTFILTER_GROUP
