I havent had this issue with rendering before but for some reason whenever I attempt to export my video from ae (after effects cc 2018) it crashes at the same point every single time. I’ve tried exporting it as something other than an avi, its not overwriting anything else, I’ve exported very similar files before, no new plugins being used or anything. There is twixtor in it which might be the problem but I’ve exported other videos with twixtor without a problem before. I’ve tried many things that have been suggested for other people but nothing is working. It’s only 16 seconds long.
Thank you! I think the issue was that the file was corrupt so I had to scrap the whole thing. But in the future if it happens again I will try what you suggested and see if it works!
If it's crashing at the same point every time, there's something about that spot that's killing it. You can try troubleshooting by turning layers/effects off until you pinpoint which it is, and then see if there's a way to prerender that element or otherwise work around it.
Have you tried clearing your cache?
Edit > Purge > All ...
If not, you can also try disabling GPU rendering, to see if that helps.
File > Project Settings > Video Rendering and Effects > Use: Software Only
Sometimes a fix for this: Create a new project, import this troublesome one into it.
thank you this worked for me!
I found the problem, for me anyways
Check the "Secret" Tab in preferences and make sure your Disable layer cache is at 0,
for some reason mine was set to 1 and stopped my render about the same spot every time,
Played with my render but now i can switch to GPU and Software only without any trouble.
Running both 2018 and 2019 cc, worked on both.
If you don't know how to access the secret preference tab, just hold shift when you click on any sub category in preferences and you will see a tab entitled "Secret" at the base of your subcategories.
