Hi There,
I'm running into an issue on macOS when passing strings with UTF-8 characters into the system.callSystem() method. I'm using AE 15.1.1 and macOS 10.13.5. On Windows, this test code works fine.
This is the very simple and basic code I'm using within the ESTK:
var cmd = "echo 'Does this character work? => x'"
$.writeln(cmd)
system.callSystem(cmd)
Here are some test strings and the results as listed in the ESTK Javascript Console window.
1.
Test string
ESTK Javascript Console Result
Result: Does this character work? => x
2.
Test string
"echo 'Does this character work? => ©'"
Result: Does this character work? => ÔøΩ
3.
Test string
"echo 'Does this character work? => ב'"
Result: Does this character work? => ?
4.
Test string
"echo 'Does this character work? => Ă'"
5.
Test string
"echo 'Does this character work? => ”'"
(note that this is a closed curly quote)
None. Both ESTK hangs until the "stop button" is pressed. When the "run button" is pressed again, ESTK reports a very strange error, then and AE and ESTK freeze and require a force quit:
After Effects error: NSInvalidArgumentException: *** [__NSArrayM InsertObject:atIndex:]: object cannot be nil
As you can see above, in some cases the character is returned perfectly. In other cases, the character is shown as a question mark, and then in others it crashes both ESTK and AE.
Does anybody have any information as to why this happens? Am I missing something in either my code or my OS config? Any help is appreciated!
Thanks!
Yep, that problem has been there for a while and the only way to fix that is to use .sh scripts with UTF-8 encoding and Mac .lineFeed.
Thanks Alex, was going nuts for a while trying to understand the issue. I’ve moved over to placing the code in a .sh file and then invoking that bash file using the system.callSystem method.
