1 Reply Latest reply on Apr 27, 2008 7:39 PM by peterent
    Problems with Flex 2 application align
    todanito
      Hi. Im new in this, but i'm going to try....
      I have a problem becouse my flex 2 application its NOT aligned to the center of the screen, as you can see in http://www.felipecabrerafotografia.com. It is aligned to the left. I'd like to know how do I change the alignment of the swf movie. Is it changing the HTML source code adding table tags?, in that case this is the HTML source code that load the flex 2 application. Thanks in advance.
      <!-- saved from url=(0014)about:internet -->
      <html lang="en">
      <head>
      <meta http-equiv="Content-Type" content="text/html; charset=utf-8" />
      <title></title>
      <script src="AC_OETags.js" language="javascript"></script>
      <style>
      body { margin: 0px; overflow:hidden }
      </style>
      <script language="JavaScript" type="text/javascript">
      // Globals
      // Major version of Flash required
      var requiredMajorVersion = 9;
      // Minor version of Flash required
      var requiredMinorVersion = 0;
      var requiredRevision = 0;
      </script>
      </head>
      <body scroll="no">
      <script language="JavaScript" type="text/javascript" src="history.js"></script>
      // Version check for the Flash Player that has the ability to start Player Product Install (6.0r65)
      var hasProductInstall = DetectFlashVer(6, 0, 65);
      // Version check based upon the values defined in globals
      var hasRequestedVersion = DetectFlashVer(requiredMajorVersion, requiredMinorVersion, requiredRevision);
      // Check to see if a player with Flash Product Install is available and the version does not meet the requirements for playback
      if ( hasProductInstall && !hasRequestedVersion ) {
      // MMdoctitle is the stored document.title value used by the installation process to close the window that started the process
      // This is necessary in order to close browser windows that are still utilizing the older version of the player after installation has completed
      // DO NOT MODIFY THE FOLLOWING FOUR LINES
      // Location visited after installation is complete if installation is required
      var MMPlayerType = (isIE == true) ? "ActiveX" : "PlugIn";
      var MMredirectURL = window.location;
      document.title = document.title.slice(0, 47) + " - Flash Player Installation";
      var MMdoctitle = document.title;
      AC_FL_RunContent(
      "src", "playerProductInstall",
      "FlashVars", "MMredirectURL="+MMredirectURL+'&MMplayerType='+MMPlayerType+'&MMdoctitle='+MMdoctitle+"" ,
      "width", "950",
      "height", "800",
      "align", "middle",
      "id", "FC2",
      "quality", "high",
      "bgcolor", "#869ca7",
      "name", "FC2",
      "allowScriptAccess","sameDomain",
      "type", "application/x-shockwave-flash",
      "pluginspage", " http://www.adobe.com/go/getflashplayer"
      } else if (hasRequestedVersion) {
      // if we've detected an acceptable version
      // embed the Flash Content SWF when all tests are passed
      AC_FL_RunContent(
      "src", "FC2",
      "width", "950",
      "height", "800",
      "align", "middle",
      "id", "FC2",
      "quality", "high",
      "name", "FC2",
      "flashvars",'historyUrl=history.htm%3F&lconid=' + lc_id + '',
      } else { // flash is too old or we can't detect the plugin
      var alternateContent = 'Alternate HTML content should be placed here. '
      + 'This content requires the Adobe Flash Player. '
      + '<a href=http://www.adobe.com/go/getflash/>Get Flash</a>';
      document.write(alternateContent); // insert non-flash content
      </script>
      <noscript>
      <object classid="clsid:D27CDB6E-AE6D-11cf-96B8-444553540000"
      id="FC2" width="950" height="800"
      codebase=" http://fpdownload.macromedia.com/get/flashplayer/current/swflash.cab">
      <param name="movie" value="FC2.swf" />
      <param name="quality" value="high" />
      <param name="bgcolor" value="#869ca7" />
      <param name="allowScriptAccess" value="sameDomain" />
      <embed src="FC2.swf" quality="high" bgcolor="#869ca7"
      width="950" height="800" name="FC2" align="middle"
      play="true"
      loop="false"
      quality="high"
      allowScriptAccess="sameDomain"
      type="application/x-shockwave-flash"
      pluginspage=" http://www.adobe.com/go/getflashplayer">
      </embed>
      </object>
      </noscript>
      <iframe name="_history" src="history.htm" frameborder="0" scrolling="no" width="22" height="0"></iframe>
      </body>
      </html>
