I need to show a DXF file in an Adobe AIR application. What I have seen is
that I will probably have to convert it to a suitable file type such as FXG
for Flex. I wonder if there is any library or something to make this
conversion.
It would be fine any other ideas instead of libraries for conversion having
in mind that what I need is to show the content of DXF file into my
application.
Ale
Illustrator can import DXF and export either SWF or SVG.
If you mean you have to convert it at runtime, then I'm not sure how you would do that.
Hi Colin,
Thanks for your reply.
The main idea is to make conversion at runtime, providing the user the functionality of importing DXF files into the application to be displayed.
Ale
Could this be an option?:
You can send it DXF and get back PNG, SVG, and many other formats. If you use the free service you're limited to 1 MB files, and 50 conversions per month.
That was the first online converter I found, there may be others that are free, or at least cheaper.
