2 Replies Latest reply on Mar 31, 2008 8:20 AM by EdLaFave
    BlazeDS Data Push - Chat App
    EdLaFave
      I'm trying to learn how data push works in BlazeDS by using the following chat tutorial. The tutorial gives you a preconfigured version of Tomcat and all works well, very nice. So I took the next step and added the chat code and XML files (services-config.xml, messaging-config.xml, etc) to my pre-existing Flex project. When I deployed my web-app to Tomcat 5.5 the chat application doesn't receive any data from the server, not even an error. Anybody know what might be the difference between the preconfigured Tomcat where the chat works and my standard Tomcat 5.5? Any suggestions on how to debug this, no errors pop up and the tomcat logs are clean.
        • 1. Re: BlazeDS Data Push - Chat App
          EdLaFave Level 1
          Tomcat is finally giving me an error! However, I don't know how to fix it. Here is the error:
          quote:
          [EMST]03/31/2008 10:49:44.938 [WARN] HttpFlexSession has not been registered as a listener in web.xml for this application so no events will be dispatched to FlexSessionAttributeListeners or FlexSessionBindingListeners. To correct this, register flex.messaging.HttpFlexSession as a listener in web.xml.
          However my web.xml file is the same file where it worked in the pre-configured tomcat server that adobe gave out:
          quote:
          <?xml version="1.0" encoding="UTF-8"?>
          <!DOCTYPE web-app PUBLIC "-//Sun Microsystems, Inc.//DTD Web Application 2.3//EN" " http://java.sun.com/dtd/web-app_2_3.dtd">
          <web-app>
          <display-name>Chat</display-name>
          <description>Chat Application</description>
          <context-param>
          <param-name>flex.class.path</param-name>
          <param-value>/WEB-INF/flex/hotfixes</param-value>
          </context-param>
          <!-- Http Flex Session attribute and binding listener support -->
          <listener>
          <listener-class>flex.messaging.HttpFlexSession</listener-class>
          </listener>
          <!-- MessageBroker Servlet -->
          <servlet>
          <servlet-name>MessageBrokerServlet</servlet-name>
          <display-name>MessageBrokerServlet</display-name>
          <servlet-class>flex.messaging.MessageBrokerServlet</servlet-class>
          <init-param>
          <param-name>services.configuration.file</param-name>
          <param-value>/WEB-INF/flex/services-config.xml</param-value>
          </init-param>
          <load-on-startup>1</load-on-startup>
          </servlet>
          <servlet-mapping>
          <url-pattern>/messagebroker/*</url-pattern>
          </servlet-mapping>
          <login-config>
          <auth-method>BASIC</auth-method>
          </login-config>
          </web-app>
          Any suggestions to fix this error would be greatly appreciated.
          • 2. Re: BlazeDS Data Push - Chat App
            EdLaFave Level 1
            Just thought I'd post this for the sake of completion. Tomcat/Flex magically decided to start working and I'm 75% sure I didn't change anything. Maybe my flex app wasn't rebuilding when I thought it was?
