2 Replies Latest reply on Nov 28, 2008 3:35 AM by Karl_Sigiscar_1971
    JMS with flex
    gets0ul
      I have a problem with connection to open jms. I get an error : "cannot instantiate class : org.exolab.jms.jndi.InitialContextFactory"
      This is my flex code :
      <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="absolute" creationComplete="createChat()">
      <!-- UI Declarations -->
      <mx:Panel title="Simple Flex Chat">
      <mx:TextArea id="output" width="385" height="220" />
      <mx:TextInput id="input" width="385" enter="sendChatMessage()" />
      <mx:ControlBar horizontalAlign="center" width="385">
      <mx:Button id="clearBtn" label="Clear" click="output.text =''" />
      </mx:ControlBar>
      </mx:Panel>
      <mx:Script>
      <![CDATA[
      import mx.messaging.Consumer;
      import mx.messaging.Producer;
      import mx.messaging.events.MessageAckEvent;
      import mx.messaging.events.MessageFaultEvent;
      import mx.messaging.events.MessageEvent;
      import mx.messaging.messages.AcknowledgeMessage;
      import mx.messaging.messages.AsyncMessage;
      import mx.utils.ObjectUtil;
      private var chatPublisher:Producer;
      private var chatSubscriber:Consumer;
      private function createChat():void
      chatPublisher = new Producer();
      chatPublisher.addEventListener(MessageFaultEvent.FAULT, onProducerFault);
      chatPublisher.destination = "topic1";
      chatSubscriber = new Consumer();
      chatSubscriber.addEventListener(MessageAckEvent.ACKNOWLEDGE, onConsumerAck);
      chatSubscriber.addEventListener(MessageEvent.MESSAGE, receiveChatMessage);
      chatSubscriber.destination = "topic1";
      chatSubscriber.subscribe();
      private function onProducerFault(faultEvent:MessageFaultEvent):void
      output.text += "[Error: " + faultEvent.message.toString() + "]\n";
      private function onConsumerAck(ackEvent:MessageAckEvent):void
      output.text += "[Got ack for subscribe or unsubscribe operation]\n";
      // Note: these are the event-handling methods from above, now moved into the separate source file:
      private function sendChatMessage():void
      var msg:AsyncMessage = new AsyncMessage();
      msg.body = input.text;
      chatPublisher.send(msg);
      input.text = "";
      private function receiveChatMessage(msgEvent:MessageEvent):void
      var msg:AsyncMessage = AsyncMessage(msgEvent.message);
      output.text += msg.body + "\n";
      </mx:Script>
      </mx:Application>
      and then the configuration in the blazeds :
      <adapters>
      <adapter-definition id="actionscript" class="flex.messaging.services.messaging.adapters.ActionScriptAdapter" default="true" />
      <adapter-definition id="jms" class="flex.messaging.services.messaging.adapters.JMSAdapter"/>
      </adapters>
      <default-channels>
      <channel ref="my-polling-amf"/>
      </default-channels>
      <!--configurazione JMS Queue-->
      <destination id="topic1">
      <properties>
      <jms>
      <destination-type>Topic</destination-type>
      <message-type>javax.jms.ObjectMessage</message-type>
      <!--connection-factory>jms/flex/TopicConnectionFactory
      </connection-factory-->
      <connection-factory>JmsTopicConnectionFactory
      </connection-factory>
      <destination-jndi-name>topic1
      </destination-jndi-name>
      <destination-name>topic1
      </destination-name>
      <delivery-mode>NON_PERSISTENT</delivery-mode>
      <message-priority>DEFAULT_PRIORITY</message-priority>
      <acknowledge-mode>AUTO_ACKNOWLEDGE</acknowledge-mode>
      <transacted-sessions>false</transacted-sessions>
      <!-- (Optional) JNDI environment. Use when using JMS on a remote JNDI server. Used to specify the JNDI environment to access an external JMS provider. -->
      <initial-context-environment>
      <property>
      <name>Context.SECURITY_PRINCIPAL</name>
      <value>anonymous</value>
      </property>
      <property>
      <name>Context.SECURITY_CREDENTIALS</name>
      </property>
      <property>
      <name>Context.PROVIDER_URL</name>
      <value>rmi://localhost:1099/</value>
      </property>
      <property>
      <name>Context.INITIAL_CONTEXT_FACTORY</name>
      <value>org.exolab.jms.jndi.InitialContextFactory
      </value>
      </property>
      </initial-context-environment>
      </jms>
      </properties>
      <adapter ref="jms"/>
      </destination>
      Please help me to fix this problem
      Thanx
