I'm writing a script that would transcode all my renders after they are rendered. This is the code...
//render finished here
var command = "HandBrakeCLI -i /path/to/file/filename.mov -o /path/to/file/filename.mp4";
alert(command);
var response = system.callSystem(command);
alert(response); //never executed due to AE freezing
alert("done");
I am getting a very weird behaviour. The file "filename.mov" is successfully transcoded and placed at the specified location, but after effects freezes and blocks me out completely when it reaches
So every time I render and transcode, I need to force quit AE.
This is the only command I encountered that freezes AE. I'd much appreciate any tips on how to handle this kind of problem. HandbrakeCLI is available here: https://handbrake.fr/downloads2.php
I am running macos Sierra.
On macOS, you can send an AppleScript to the system.callSystem() method. This will spawn a new Terminal thread for your command line to run in. You can have a string in your ExtendScript code like:
var handbrakeCommand = "HandBrakeCLI -i /path/to/file/filename.mov -o /path/to/file/filename.mp4"
var sysCommand = "osascript -e 'tell app \"Terminal\" to do script \"" + handbrakeCommand + "; exit;\"' -e 'tell app \"Terminal\" to activate'";
system.callSystem(sysCommand);
osascript is Apple's standard command line interpreter for running AppleScript files. In the code above the -e switch allows you to place literal AppleScript language on the command line. You can have multiple -e switches to have osascript interpret more than one script in order.
You may need to escape some characters in the handbrakeCommand string for it to work, but the idea is to use AppleScript to launch a separate Terminal process outside of AE's main thread, and have it run your command or script asynchronously.
Hope this helps!
