2 Replies Latest reply on Jul 26, 2018 6:39 PM by cool_fritz
    Invisible arm with visible hand—Is that possible?
    cool_fritz Level 1
      Here's a weird question for you. I want to have a character with circles for hands and no visible arms. I want to be able to move the circles (hands) and have them move as if the arm were there (for the purpose of physics). Ideally the circles would not deform.
      Is this even possible in CA? I've tried creating the arms as you normally would and then making the opacity zero, but CA seems to treat that as if the element isn't there.
      John
        • 1. Re: Invisible arm with visible hand—Is that possible?
          alank99101739 Level 4
          Try using the eyeball icon to make the arm connecting the hand to the body invisible instead. I also found less than around 20% opacity in the artwork seemed to turn into “not there”. But I took an existing puppet with an arm, then in the rigging puppet hierarchy in CH turned off the eyeball for the arm group I had between the body and the hand, Ch then acts as if the arm is still there. You just need to group the hierarchy to make it easy to hide the joining arm. (For you it would be a skinny rectangle to join the circle hand to the body.)
          The following shows the hand in the scene in default position.
          The follow shows the hand dragged - see how it has changed its angle relative to the body, because it thinks its attached still? (It also stays in place when you adjust X/Y, rescale, etc)
          • 2. Re: Invisible arm with visible hand—Is that possible?
            cool_fritz Level 1
            Thank you so much! I'm such a dummy , it never occurred to me I could turn off the eye and have it work. That's exactly what I want.
