6 Replies Latest reply on Jul 27, 2018 10:34 AM by DreaB
    Previous Abode Premiere
    DreaB
      Hello,
      I would like to use Premiere Pro CC but my PC doesn't support the system requirements of the latest program.
      Where can I download the previous Premiere on the Adobe website?
      Andrea
        • 1. Re: Previous Abode Premiere
          Jim_Simon Level 9
          What requirement is missing?
          • 2. Re: Previous Abode Premiere
            DreaB Level 1
            Hello Jim,
            Especially on grafic video and motherboard's microprocessor
            • 3. Re: Previous Abode Premiere
              jasontcox Adobe Community Professional
              You can download previous versions by going to the Creative Cloud app you likely have downloaded and installed, clicking the "Apps" tab, finding Premiere and clicking the little arrow button to the right. You will see an option to display Previous Versions.
              • 4. Re: Previous Abode Premiere
                Jim_Simon Level 9
                What GPU and CPU do you have?  I'm hard pressed to think of any currently available version of the CC suite requiring different hardware.
                • 5. Re: Previous Abode Premiere
                  RjL190365 Level 5
                  Andrea,
                  You need to tell us specifically which GPU and CPU that you have in your PC. If, for example, you have a 15-year-old PC that's only capable of running 32-bit programs, then you're completely out of luck: All currently downloadable versions of Premiere require 64-bit software and hardware support.
                  By contrast, if you have a system that's already 64-bit ready but is restricted in its maximum RAM support to only 4GB, then your only choices that are currently available are the original CC 2013 release and the CS6 release. (Versions between the 2014 version and the 2017.1.2 version are no longer available due to a licensing dispute between Adobe and Dolby Laboratories.) Likewise, those are the only two versions that are usable in a system that has only a Tesla-architecture GPU such as a GeForce GTX 200 series since all currently available newer versions require driver version 365 or higher to enable GPU acceleration whereas the Tesla-architecture GPU drivers go no higher than version 342. And if your system's CPU has only a single physical CPU core, forget about it.
                  Randall
                  • 6. Re: Previous Abode Premiere
                    DreaB Level 1
                    I have a quite intention to buy a new PC from my work.
                    I am going to choose a YOGA model (Lenovo Company) because it closes the most commons use that I need.
                    Which type of Lenovo YOGA should I choose in order to have the possibility to run Premiere Pro CC ?
