Hello,
I know and understand liquid but the thing is... I just can't seem to wrap my head around using things like the {{itemid}} for web apps and putting them to good use.
Can someone please give me a good example on how to use liquid tags to ouput {{..}} a web app item. This will be helpful just a simple example please!!
Look a the docs:
Web App list layout | Business Catalyst Developers
Liquid is pure data. Where the old BC tags used to output either a value or wrap that in HTML sometimes with options - Liquid output is more about just data and you handling that data.
With that Liquid Markup is more then this, it is all the logic you can apply:
Logic tags | Business Catalyst Support
And all the data manipulation as well from things like filters.
The docs also come with code examples:
Conditionals | Business Catalyst Support
You really should not spend to much time on learning BC's version of liquid markup since BC is going to end of life. You should look to be migrating sites and learning the new system you will be migrating too.
