• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Character doesn't follow my movements
Community Beginner ,
Jul 30, 2018 Jul 30, 2018
Hello, everyone.
So, I'm trying to learn the Character Animator by building characters and, so far, they don't match my movements very well. The eyes don't match my eye movements half the time and the mouth doesn't match the sounds I'm making most of the time. I usually practice this in a quiet area, so there's not other noise to interfere with the audio intake and I try to have my face well-lit, so I don't see why the camera isn't able to follow me. What can I do?
Thank you.
Views
540
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Jul 31, 2018 Jul 31, 2018
For eye gaze, are you using the web cam? I find it useful, but not that accurate. Eye gaze has "snap eye gaze" which locks the eyes to 9 positions (up down left right and combinations thereof). This stops eye jitter. If you turn this off, I recommend disabling camera input under Eye Gaze and use the mouse/touch input instead. You get much better control over the eyes that way. (This is personal opinion - but I have had times I am looking directly at the screen and the eyes bound around a bit - n
Votes
Translate
Translate
LEGEND ,
For eye gaze, are you using the web cam? I find it useful, but not that accurate. Eye gaze has "snap eye gaze" which locks the eyes to 9 positions (up down left right and combinations thereof). This stops eye jitter. If you turn this off, I recommend disabling camera input under Eye Gaze and use the mouse/touch input instead. You get much better control over the eyes that way. (This is personal opinion - but I have had times I am looking directly at the screen and the eyes bound around a bit - not a lot, but enough to feel uncomfortable watching it.)
Mouth positions (from the Face behavior) are controlled by sound, except for smile and surprise (they are from the web cam). So a well lit face for "lipsync" probably won't help. I would make sure the recording level is high enough etc. One way to test this is to do a recording and see how high the waveform is. I typically use Adobe Audition instead of recording inside Character Animator, because it has a "Normalize" effect to normalize the amplitude (makes it louder if needed). I then load that sound file into Character Animator and use "Compute Lipsync from Scene Audio" in the menus. The other thing you can do (for testing) is after recording a dummy lipsync, you can right click in the timeline and add your own visemes by hand. Its tedious and boring, but you can then make sure the mouth positions work correctly. If adding by hand looks good, then I would guess microphone volume problems as the most likely cause of sub-standard results.
But the tools are not perfect. Good, but not perfect. They do play up at times.
Votes
Translate
Translate
Report
Report
Contributor ,
LATEST
One of the things I've heard is that lighting on your face makes a big difference. In other words, make sure you are in a bright room.
I write animated children's songs, and personally I prefer to use triggers with facial expressions and the import lip sync more than actually input.  Good luck.
Votes
Translate
Translate
Report
Report
