9 Replies Latest reply on Dec 5, 2018 2:49 PM by timwilson7
    Connecting to Power BI
    nataliap18526733 Level 1
      Hi
      Trying to connect Power BI to Adobe Analytics but after I put in my Adobe ID it is giving me a grey screen.
      Could you help?
        • 1. Re: Connecting to Power BI
          PratheepArunRaj Experience Cloud MVP
          Dear Natalia,
          Have you verified that you are using the latest version of Report Builder? If not, please update.
          Then try to follow the trouble shooting techniques from the links Troubleshooting Power BI Integration  and Troubleshooting and Best Practices for Report Builder. If not, kindly reach Adobe Customer Care : CustomerCare@adobe.com.
          Thank You
          Arun
          • 2. Re: Connecting to Power BI
            Hi Arun,
            It is not a connection from Report Builder I am trying to connect from Power BI Desktop to Adobe Analytics as a data source. It works for my colleague so should be some issue with my User ID from Adobe side. I emailed Customer Care email but autoreply says my email is not supported which is very strange.
            Natalia
            • 3. Re: Connecting to Power BI
              Dear Natalia,
              If you cannot raise Adobe Customer Care request, you are not supported user for Adobe Analytics.
              Contact your Adobe Analytics Account Manager and they should definitely help you.
              Thank You
              Arun
              • 4. Re: Connecting to Power BI
                Gigazelle Adobe Employee
                Hi Natalia, were you able to get the issue resolved?
                • 5. Re: Connecting to Power BI
                  jackcbennett
                  Hello, did you ever resolve this? We're experiencing the same issue so would be great to know if you managed to get any further!
                  Jack
                  • 6. Re: Connecting to Power BI
                    timwilson7 Level 1
                    Gigazelle While nataliap18526733 has not responded, I don't think this post should be assumed answered. I am experiencing this issue as well, as is jackcbennett. The steps I'm following:
                    1. Selecting Adobe Analytics as the Data Connector from within Power BI Desktop
                    2. I get told to sign in with my Adobe ID in a pop-up window.
                    3. I enter my Adobe ID username and password and click Sign In.
                    4. The popup just goes to all gray. If I move it out of the way, the original prompt is saying "You are being signed in, please wait..." And there is a "Sign in..." message on a button with the spinning circle.
                    Nothing happens from there. IF I close the gray popup window, then the original prompt changes back to just saying "You are not signed in" with a "Sign in" button below it. But there is also a yellow ribbon that says, "We're unable to connect. Please delete your credentials and try again later."
                    I'm not sure how/where to delete my credentials.
                    I'm trying this on a pretty clean Windows 10 install with a fresh Power BI Desktop install.
                    Any ideas?
                    • 7. Re: Connecting to Power BI
                      Hey Tim, great seeing you here. While I don't have an answer to the Power BI issue, I've reopened the question so we can hopefully get some additional input.
                      • 8. Re: Connecting to Power BI
                        matth87885335 Level 1
                        Natalia,
                        I was having the same problem and may have a fix for you.
                        Using Wireshark and Fiddler, we were able to find the login request url that Power BI Desktop uses. It starts with something like:
                        "https://ims-na1.adobelogin.com/ims/authorize/v1?client_id=MarketingCloudWS1&redirect_uri=h ttps....."
                        Taking the complete url from the login request, I pasted it into Chrome and the Adobe Marketing Cloud login appeared. After entering my credentials and logging in, the Chrome screen turned blank.
                        I then re-opened Power BI Desktop and began the Get Data connection process to Adobe. Power BI immediately established a connection, bypassing the login prompt, and I was able to access our Adobe data in Power BI.
                        I am, however, experiencing an issue where I can only see 1 of the 3 Instances to which I have access. This may be due to the workaround in connecting to Adobe but I'm not sure. I have another ticket open with Client Care to investigate.
                        But please feel free to attempt this workaround and hopefully it works for you!
                        Good luck!
                        - Matt
                        2 people found this helpful
                        • 9. Re: Connecting to Power BI
                          timwilson7 Level 1
                          Thanks, Matt!
                          Since I was bumbling along a little bit (and working to get this working on a Windows VM that was a pretty fresh install), I'll add a couple more bits of detail:
                          1. Download Fiddler
                          2. Make a filter for Show only if URL contains adobelogin
                          3. Launch Power BI Desktop and go to Get Data and select the Adobe Analytics connector
                          4. At some point, walking through the (failing) login process, you'll see the request appear in Fiddler and you can copy the URL (starts with the pattern above and is a bit of a beast)
                          5. Paste that into your browser and you'll get prompted to log in with your Adobe ID and then click to authorize the connector.
                          6. Return to Power BI Desktop and cancel out of the login process (maybe not necessary, but that's what I wound up doing).
                          7. Start the Adobe Analytics connector again, and you should show as already being connected and be good to go!
                          Thanks again for figuring that out, Matt. I'd pretty much thrown up my hands and given up.
