• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Background audio stabilization on slides that include narration...
Community Beginner ,
Aug 01, 2018 Aug 01, 2018
Hello All,
After adding some background music to my project I realized there are high's and low's on some of the slides. I've tried to adjust the volume, selected the option of Adjust background audio volume on slides but this has not worked.  On a few slides, the music is louder than the narration vs other slides where you can barely hear the music. Any suggestions?
I'm using Captivate 9...
Views
465
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guide ,
Aug 04, 2018 Aug 04, 2018
Are you sure each clip for each slide is the proper/same volume level you want?
Do you have an external audio editor - perhaps Audition or Audacity (free)?
I'd recommend you extract all the audio clips and check them in an external editor.
Use that tool to equalize each track (i..e bring backgrounds down lower).
Import a few into a new CP project and see if they then play as you intend.
If so, try in the original project - either by updating the audio (from the properties) or by removing the original audio and re-importing the new audio.
Helps?
Votes
Translate
Translate
Report
Report
Aug 07, 2018 Aug 07, 2018
The narration volume is fine. Its when I add the background music (taken from YouTubes free music library) where the volume fluctuates. If put this into Audacity and its fine. As soon as I bring it back into Captivate, the volume gets wonky.... any other thoughts? Erik Lord
Votes
Translate
Translate
Report
Report
Guide ,
Aug 20, 2018 Aug 20, 2018
Been a bit since this post, apologies. Maybe its a format issue - what's the format and details of the file for the background music? Is it mp3 already? How's the quality? What if you convert to a .wav with Audacity then bring that into CP as the background track?
Votes
Translate
Translate
Report
Report
Aug 21, 2018 Aug 21, 2018
Thanks, Erik. I will try converting it to a .wav file and bring that in.  Fingers crossed.
Votes
Translate
Translate
Report
Report
Explorer ,
Jul 20, 2020 Jul 20, 2020
LATEST
I also have the same issue. When I add background music to the slides that has narration, i also have the same issue where when there is a slight pause, music gets high. Music sounds good when the narration is playing. Only when there is a pause, this happens.
I tried the background settings but nothing seems to help. Any suggestions to fix this issue?
Jaya
Votes
Translate
Translate
Report
Report
Community Expert ,
Try to use the Adobe Media Encoder packaged with Captivate to do another conversion to mp3...
Votes
Translate
Translate
Report
Report
Sure... thanks!
Votes
Translate
Translate
Report
Report
Community Expert ,
Can you also check the exact version number (Help, About Captivate)? Just to be sure you are using the most recent version which is 9.0.2.437.
Votes
Translate
Translate
Report
Report
Yes, the version is 9.0.2.437
Votes
Translate
Translate
Report
Report
Resources
Help resources
