• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Arboards in navigator and rotation features
Community Beginner ,
Aug 01, 2018 Aug 01, 2018
When I work with multiple artboards that are large, it's annoying to see all of the artboards because then I can't focus on a few artboards or just one so that i can see how it looks like when it is small. It would be also cool to be able to rotate artboards as well. I know photoshop has the r hotkey to rotate, so a feature like that on Illustrator would be cool.
TOPICS
Scripting
Views
500
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe
Participant ,
Aug 03, 2018 Aug 03, 2018
LATEST
If I get you right, as for the rotation of the artboard, there is a solution:
// Artboards_Rotate_With_Objects.jsx for Adobe Illustrator
// Description: A script to rotate 90 degrees an active artboard with all the objects on it.
// Requirements: Adobe Illustrator CS6 and above
// Date: July, 2018
// Authors: Alexander Ladygin, email: i@ladygin.pro
// Sergey Osokin, email: hi@sergosokin.ru
// Installation:
// 1. Place script in:
// Win (32 bit): C:\Program Files (x86)\Adobe\Adobe Illustrator [vers.]\Presets\en_GB\Scripts\
// Win (64 bit): C:\Program Files\Adobe\Adobe Illustrator [vers.] (64 Bit)\Presets\en_GB\Scripts\
// Mac OS: <hard drive>/Applications/Adobe Illustrator [vers.]/Presets.localized/en_GB/Scripts
// 2. Restart Illustrator
// 3. Choose File > Scripts > Artboards_Rotate_With_Objects
// NOTICE:
// Tested with Adobe Illustrator CC 2017/2018 (Mac).
// This script is provided "as is" without warranty of any kind.
// Free to use, not for sale.
// Released under the MIT license.
// http://opensource.org/licenses/mit-license.php
#target illustrator
app.userInteractionLevel = UserInteractionLevel.DONTDISPLAYALERTS;
var scriptName = 'ARWO',
   scriptVersion = '0.2';
try {
   if (documents.length > 0) {
   var doc = app.activeDocument,
   currArt = doc.artboards[doc.artboards.getActiveArtboardIndex()],
   currArtNum = doc.artboards.getActiveArtboardIndex() + 1,
   lockedItems = new Array(),
   hiddenItems = new Array();
   // Create Main Window
   var dlg = new Window('dialog', scriptName + ' ver.' + scriptVersion, undefined);
   dlg.orientation = "column";
   dlg.alignChildren = ["fill", "fill"];
   // Target radiobutton
   var slctTarget = dlg.add("panel", undefined, "What to rotate?");
   slctTarget.orientation = "column";
   slctTarget.alignChildren = ["fill", "fill"];
   slctTarget.margins = 20;
   var currArtRadio = slctTarget.add('radiobutton', undefined, "Active Artboard: #" + currArtNum),
   allArtRadio = slctTarget.add('radiobutton', undefined, "All " + doc.artboards.length + " Artboards");
   currArtRadio.value = true;
   // Angle radiobutton
   var slctAngle = dlg.add("panel", undefined, "Rotation angle:");
   slctAngle.orientation = "row";
   slctAngle.alignChildren = ["fill", "fill"];
   slctAngle.margins = 20;
   var cwAngle = slctAngle.add('radiobutton', undefined, "90 CW"),
   ccwAngle = slctAngle.add('radiobutton', undefined, "90 CCW");
   cwAngle.value = true;
   // Buttons
   var btns = dlg.add('group');
   btns.alignChildren = 'center';
   btns.margins = [0, 10, 0, 0];
   var cancel = btns.add('button', undefined, "Cancel");
   cancel.helpTip = "Press Esc to Close";
   var ok = btns.add('button', undefined, "OK");
   ok.helpTip = "Press Enter to Run";
   ok.active = true;
   cancel.onClick = function () { dlg.close(); }
   ok.onClick = okClick;
   dlg.center();
   dlg.show();
   //Start
   function okClick() {
   // Saving information about locked & hidden pageItems
   saveItemsState();
   // Rotate active artboard or all artboards in document
   if (currArtRadio.value == true) {
   rotateArt(currArt);
   } else {
   for (var i = 0; i < doc.artboards.length; i++) {
   doc.artboards.setActiveArtboardIndex(i);
   rotateArt(doc.artboards);
   // Restoring locked & hidden pageItems
   restoreItemsState();
   dlg.close();
   } else {
   throw new Error(scriptName + "\nPlease open a document before running this script.");
} catch (e) {
   alert(e.message, 'Script Alert', true);
// Save information about locked & hidden pageItems
function saveItemsState() {
   for (var i = 0; i < doc.pageItems.length; i++) {
   var currItem = doc.pageItems;
   if (currItem.locked == true) {
   lockedItems.push(i);
   currItem.locked = false;
   if (currItem.hidden == true) {
   hiddenItems.push(i);
   currItem.hidden = false;
function restoreItemsState() {
   for (var i = 0; i < lockedItems.length; i++) {
   var index = lockedItems;
   doc.pageItems[index].locked = true;
   for (var j = 0; j < hiddenItems.length; j++) {
   var index = hiddenItems;
   doc.pageItems[index].hidden = true;
// Main function for rotate artboard
function rotateArt(board) {
   var artRect = board.artboardRect,
   artWidth = artRect[2] - artRect[0],
   artHeight = -(artRect[3] - artRect[1]);
   deselect();
   doc.selectObjectsOnActiveArtboard();
   // Rotate artboard
   var newArtRect = [
   artRect[0] + artWidth / 2 - (artHeight / 2),
   artRect[1] - artHeight / 2 + (artWidth / 2),
   artRect[2] - artWidth / 2 + (artHeight / 2),
   artRect[3] + artHeight / 2 - (artWidth / 2)
   board.artboardRect = newArtRect;
   // Rotate objects
   for (var k = 0; k < selection.length; k++) {
   var bnds = selection.geometricBounds,
   top = bnds[1] - artRect[1],
   right = bnds[2] - artRect[2],
   left = bnds[0] - artRect[0],
   bottom = bnds[3] - artRect[3];
   // selection.rotate(90);
   if (cwAngle.value == true) {
   // rotate 90 CW
   selection.rotate(-90);
   selection.left = newArtRect[0] + bottom;
   selection.top = newArtRect[1] - left;
   } else {
   // rotate 90 CCW
   selection.left = newArtRect[0] - top;
   selection.top = newArtRect[1] + right;
   deselect();
function deselect() {
   activeDocument.selection = null;
Votes
Translate
Translate
Report
Report
