Hi, i'm following this README => GitHub - Adobe-CEP/Getting-Started-guides: Getting Started guides and samples for CEP extensions
And i'm stuck in the very early stages cause i don't see my Extension at all on InDesign ( i do changed the host in my manifest.xml file, adding this =>
<Host Name="IDSN" Version="[10.0,10.9,13.1]" />
in the <HostList>
I'm working on windows, and i did added the register key => PlayerDebugMode = 1 in HKEY_CURRENT_USER / Software / Adobe / CSXS.5 ( and CSXS.4 and CSXS.8,... ), and my IndesignVersion is the 13.1 x64,...
I don't even know where i should start looking to troubleshoot my problem, i'm just trying to follow the first tutorial >___<"
I'm lost here, if anyone could give me any hints, i would be really grateful !
Thanks o/
PS : it might be the wrong place to ask, i wasn't really sure, if so, please excuse me and tell me so, i'll go ask to the right place !
Discussion successfully moved from InDesign Scripting to Extensions / Add-ons Development
In the host list, there should be only two values at max, min et max version your extension is planned to work with:
<Host Name="IDSN" Version="[10.0,13.1]" />
should work better
Also where did you put the extension ?
Eventually, you would need a restart.
If none of these work, put your manifest here.
or if you just want to set a min value <Host Name="IDSN" Version="[10,99]" />
or <Host Name="IDSN" Version="10" /> with no [brackets]
Hi, sorry for the delay, i had to work on something else,...
Anyway, i did modified my manifest.xml wich looks now this way =>
And i did pu my extension at this path =>
C:\Users\myuser\AppData\Roaming\Adobe\CEP\extensions\
Any help would be really appreciated
After editing registry key, did you restart ?
Does the extension menu appears at least ?
Are you certain html and jsx files are placed where you declared them ?
Don't they have any syntax issues ?
Don't your html call for some unavailable library ?
And so on…
