2 Replies Latest reply on Aug 17, 2018 4:38 AM by s.jonsson
    Indesign tagging text with two tags
    s.jonsson Level 1
      I need to tag a text twice in extendscript.
      Example:
      A simple example below:
      var textStyleRanges = app.selection[0].texts[0].textStyleRanges.everyItem().getElements(); //I have a textFrame Selected
      app.activeDocument.xmlElements.item(0).xmlElements.add ("Story", app.selection[0]); //I tag the frame with Story
      app.activeDocument.xmlElements.item(0).xmlElements.add ("Tag1", textStyleRanges[0]); //I add Tag1
      app.activeDocument.xmlElements.item(0).xmlElements.add ("Tag2", textStyleRanges[0]); //I would like to add Tag2 inside Tag1
      Now I need to add another tag inside Tag1 for the same text so it looks like this
      <Tag1><Tag2>My text</Tag2></Tag1>
      The problem is, when adding Tag2, The first tag gets replaced with Tag2 so it looks like this:
      I Understand why, but not how to solve it like I would like.
      Any suggestions?
        • 1. Re: Indesign tagging text with two tags
          Loic.Aigon Adobe Community Professional
          As you tag, references change (added tag characters push indeces away). Reference again your tag.
          var tf = app.selection[0];
          var txt = tf.parentStory.texts[0];
          var doc = app.activeDocument;
          var root = doc.xmlElements.item(0);
          root.xmlElements.add ("Story", tf);
          txt = root.xmlElements.add ("Tag1", txt ).xmlContent.texts[0];
          root.xmlElements.add ("Tag2", txt );
          Out of check on the context (sel, story…).
          • 2. Re: Indesign tagging text with two tags
            s.jonsson Level 1
            Thanks Loic,
            I understand what you mean, but...
            How can i make that work here?
            //TAG ALL PARAGRAPHS WITH "ParaText"
            var paraArr = app.activeDocument.stories[0].tables[0].cells.everyItem().paragraphs.everyItem().getElements();
            for (var x = paraArr.length - 1; x >= 0; x--){
                app.activeDocument.xmlElements.item(0).xmlElements.add ("ParaText", paraArr[x].paragraphs[0]);
            //TAG ALL THAT HAS FONTSTYLE BOLD USING TEXTSTYLERANGES
            var paraArr = app.activeDocument.stories[0].tables[0].cells.everyItem().texts.everyItem().getElements();
                var textStyleRanges = paraArr[x].textStyleRanges.everyItem().getElements();
                for (var y = textStyleRanges.length - 1; y >= 0; y--){
                    if (textStyleRanges[y].fontStyle == "Bold"){
                        app.activeDocument.xmlElements.item(0).xmlElements.add ("Bold", textStyleRanges[y])];
            I think the main problem occurs when also the linebreak is in Bold.
            Example:
            My bold text with the linebreak Bold
            Some other text
            If I remove the Bold from the linebreak, it works OK.
            I have a solution like this:
            if (textStyleRanges[x].characters[-1].contents == String.fromCharCode(13)){
                 var myNewRange = textStyleRanges[x].characters.itemByRange(0,-2);
            But I think it's an ugly solution....
            Any ideas?
