2 Replies Latest reply on Aug 8, 2018 12:44 PM by twaritar3263062
    I need an image for a splashback...
    SparkleCarter Level 1
      Hi Guys, I'm looking to purchase 1 or more images for a splashback. The splashback is 330cm wide by 70cm high. Do you have any images that will enlarge to that size without compromising the quality of the image? If you do, how do I identify the correct size of the image?
      I have experience using stock photos for advertising but have never needed to find one so big! Help would be MUCH appreciated!
      Cheers
      SparkleCarter
        • 1. Re: I need an image for a splashback...
          Abambo Adobe Community Professional
          Take one of your pictures and see if they can be reproduced at that size. When you know what your quality requirements would be, look finding a motive that fits your needs. It needs to be a panoramic picture. Depending on the viewing distance, the resolution could be quite high. You will have probably some possibility to enlarge using Photoshop or the like.
          2 people found this helpful
          • 2. Re: I need an image for a splashback...
            twaritar3263062 Adobe Employee
            Hi Sam,
            Thanks for reaching out to the Adobe Stock community.
            The size or dimension of the files are mentioned below each image as shown in the screenshot:
            Additionally, all Adobe Stock content is provided at its highest available resolution. While this resolution depends on the camera used to originally capture the asset, most of the content can accommodate high-quality printed output up to 300 dpi.
            Also, the vector files can be printed in all formats without loss in quality. You may also refer to Common Questions, Adobe Stock for more details.
            However, I would like to let you know that since you are using these assets for splashback, you will be requiring an Extended license for the assets since under extended license asset may be featured in merchandise or products for resale.
            For more information on the licensing terms and restrictions please refer to Stock Licensing & terms FAQ: Where can I find the terms and licensing information for Adobe Stock?
            Hope this information helps!
            Feel free to update this thread in case of any additional questions.
            Regards,
            Twarita
            3 people found this helpful
